HELP ASAP brakes
Old 04-30-2008, 11:58 AM
dcmbsc's Avatar
HELP ASAP brakes
On my 94 pickup we just replaced all the brake hardware and master and we got every put in. The only problem is we can't get all the air out of the lines, weve tried everything , hand vacum bleeder , hose from above the truck with funnle trying to push the air out of the lines we cant get it all out. we gotta get the truck outta my garage , help please!!!!!
Old 04-30-2008, 12:03 PM
zlathim's Avatar
Make sure that the rears are adjusted up appropriately. Out of adjustment rear brakes feel just like unbled brakes.
Old 04-30-2008, 12:04 PM
dirtoyboy's Avatar
Are you bleeding the LPSV last? Did you bench bleed your master cylinder?
dcmbsc's Avatar
i just putt the truck in neutral and matted the brakes , the pedal gos all the way to the floor and just rolls!
Old 04-30-2008, 12:27 PM
eric-the-red's Avatar
Did you replace the calipers, and if so have you got them on the corrrect side of the truck. The bleed screws have to be at the top. And like dirtoyboy said the new master has to be bench bled first, it should have come with instructions on how to do this. And the lspv needs to be done after all the wheels.
Old 04-30-2008, 12:38 PM
iamsuperbleeder's Avatar
https://www.yotatech.com/forums/f116...p-asap-144009/
Similar thread; may be of some help...
Old 05-01-2008, 04:29 AM
PCE91V64x4's Avatar
Confirm the LSPV (bleed it again). You will have about 10% braking power if everything is together properly and you do not bleed the LSPV last (or at all). I know this from experience.
Good luck! troubleshooting brakes is a bear.
nvdesertrunner
05-11-2020 08:18 PM
old87yota
09-09-2015 12:39 PM
Scatterbrain
09-03-2015 06:46 PM
bfmcelroy
08-18-2015 06:42 AM
CanRunner
07-20-2015 01:29 PM
Quick Reply: HELP ASAP brakes
