Help with another rusty frame
Old 08-18-2009, 06:42 PM
jetpilot's Avatar
The frame on my '87 pickup has started to rust from the inside out. I've gone so far as to power wash the crap out of it and shop vac everything that was left. The inside is quite clean now and I'm wondering how to prevent futher rusting. Should I go through the hassle of POR 15-ing it or should I just fill the frame with oil every now and then? The outside of the frame is in perfect condition.
Old 08-18-2009, 08:02 PM
sb5walker's Avatar
The inside of the frame is the one place on our trucks that defies all attempts to stop the rust. It's the inside of the welded joints that turn into a pockets of moisture and corrosion, and you can't stop it. You can slow it down some - temporarily, but whether it is worth the work and expense depends on how far gone it is.
Here are a couple posts from over on toyota nation that might be of some use. The two methods basically are treating with a rust remover or a rust converter, and then a topcoat like POR-15 or KBS RustSeal (if you use a remover) or a good chassis paint (if you use the recommended converter - Fertan). How you'll get these applied inside the frame is another question entirely - no easy task, and maybe almost an impossible one. But for whatever it's worth:
From: http://www.toyotanation.com/forum/sh...11#post2799311
Originally Posted by pickup
So, I never received an answer about how to clean them up. There is a little rust and pitting. I'm thinking Steel wool? But I don't know if how that will work.
Originally Posted by sb5walker
I've been wanting to write this up for a while, may as well be now. I learned about rust when I owned a 1964 Triumph TR4. For as long as I owned the car, I was engaged in an epic life-or-death battle with rust. I learned a lot - mostly what doesn't work - as I experienced fun things like having a rear fender fall off while rounding a curve, and, even more fun, having the steering gearbox break free of the rotting frame, jamming the steering just as I entered a curve. Both I and the owner of the brand-new split rail fence I destroyed found that episode quite amusing. :rolleyes: Anyway, maybe this will help someone protect their truck:
There are two fairly effective ways to treat surface rust. I say fairly effective because nothing will work 100% or last forever. But you can knock it back pretty well.
The first approach is to use a "rust dissolver", also called a rust "remover". That's a phosphoric acid etching solution, sometimes with added ingredients. Naval Jelly and Ospho are probably the two most popular. You absolutely must cover the treated area with an impervious oxygen and moisture barrier, otherwise the rust will start up again quite soon, sometimes within hours.
The second is to use a "rust converter" which chemically reacts with iron oxide to produce a compound that inhibits further rust. By itself, a rust converter will last much longer than a rust dissolver by itself, but ultimately a converter also needs an impervious topcoat for the longest lasting effect. Originally, rust converters were based on phosphoric acid, since it reacts with iron to produce iron phosphate, which provides the steel some protection from further rust. The best converters now use tannic acid, which reacts to produce iron tannate - a much more durable rust preventative than iron phosphate.
Most people who have treated rust with dissolvers or converters have found that they don't work for long on vehicles. The reason is salt. The salt ions actually chemically and electrically alter the steel to cause it to generate low voltage electricity that essentially does electro-plating in reverse: instead of depositing metal, the salt causes the metal to be electrically eroded. If steel has been in contact with road salt for an extended period, it is practically impossible to remove the chlorides from the steel, so even if you treat it with rust converter, the steel will still electrochemically corrode.
I actually did find a product that worked amazingly well on my old TR4 - for the surface rust. The problem was that by the time I found the product, most of the body and frame of my poor TR4 was shot through with rust, and when that happens, nuttin helps.
The product that worked quite well is "Fertan". It was developed for the British Navy, and it is used widely in the marine industry around the world. The reason Fertan works well is that it contains zinc. Zinc is electrically a more active "anode" than steel, and when in contact with steel it will sacrifice itself and protect the steel. Most ocean-going vessels have zinc clamped to the propeller shaft to protect the shaft and propeller from corrosion.
There's some info about Fertan here:
http://www.toyotanation.com/forum/sh...25#post2764125
Fertan is great for the frame/suspension, especially if it's top-coated with one of the chassis paints listed in the post linked above.
BUT. The problem with Fertan is that it is somewhat "thick". It needs to be thick to provide a reservoir of zinc. For that reason, I'm not sure whether it would work for the inside of the wheel. I would worry that the surface would not be smooth enough to provide an air-tight seal for the tire.
So in your case, the rust dissolver/impervious topcoat approach might work better. Fortunately, there is a great dissolver that also contains zinc - and it probably would work well for those wheels. It's called "RustBlast" and it's made by KBS, a maker of coatings similar to (but I think better than) POR-15's product line. RustBlast is mainly phosphoric acid - it does dissolve rust like naval jelly or Ospho, but it also contains zinc phosphate that counteracts the chlorides that have infected the steel. It should be top-coated with KBS's "RustSeal" product or with POR-15. That provides a smooth, glossy, impervious finish that is very tough and also should provide a nice airtight seal for your tires.
Surface prep is everything, so you may want to sand the rusty areas smooth, clean and degrease the area with something like KBS's AquaKlean, then treat with RustBlast, and finish up with RustSeal. That's the best thing I can think of for those wheels.
http://www.kbs-coatings.com/Prep-Products_c_1-1-0.html
http://www.kbs-coatings.com/Rust-Sealer_c_2.html
http://www.kbs-coatings.com/KBS-Syst...-Kit_p_23.html
Oh yeah. I lost that life-or-death struggle with rust on the old Truimph. I learned that once rust has gone deep, nothing can stop the metal from returning to Mother Earth. I gave what was left of the car to another TR4 owner to use as a parts car. Too bad - that car had more "soul" than any vehicle I've ever driven.
From: http://www.toyotanation.com/forum/sh...25#post2764125
You could claw your way out of most anything with those bad boys - those are NICE! :thumbsup:
If fact, the whole truck is nice.
In the spirit of keeping it nice, here's a product to fight back against those Michigan winters and that salt-caused rust:
http://www.retro-uk.com/fertan.htm
http://www.fertan.de/katalog/english/katalog.htm
Where to order in the U.S.: http://www.fertanamerica.com/
Fertan is used by a lot of navies and commercial marines because it deals better with rust caused by salt - it has zinc in the mixture which helps neutralize the salt ions. It was the only product that made any difference on my rust bucket '64 Triumph TR4. It works best if you apply a topcoat after it's cured, with something like Eastman's Extreme Chassis Black, KBS BlackTop or POR-15's Chassis Coat Black
kawazx636
10-06-2021 03:03 PM
ladybugRC
458
08-21-2020 10:41 AM
RDubya
02-10-2017 04:46 PM
live4soccer7
05-11-2016 06:52 PM
hiluxinargentina
09-30-2015 11:12 PM
Quick Reply: Help with another rusty frame
