Help 92 22RE won't start
Old 10-03-2012, 09:00 AM
GrandPrix's Avatar
Let me say I did a search but can't find exactly my situation.
Replaced the coolant temp sensor and then installed a cold air intake.
Went to start but it shuts off after two to three seconds of running. The check engine light came on too.
What did I do wrong and how do I fix it?
I am assuming it has something to do with the MAF sensor. I did not touch the TPS.
Many thanks in advance for the help.
If it won't run, I will have to get a tow to my mechanic.
Old 10-03-2012, 12:20 PM
GrandPrix's Avatar
Ok, so tested the MAF and one circuit did not test so I went and ordered a replacement. I just hope this was a coincidence.
I will report back with results.
Old 10-03-2012, 01:02 PM
TNRabbit's Avatar
It's not a MAF; it's a Volume Air Flow Meter (VAFM). You probably pulled something loose when you removed it. Did you remove the screws to the attachment or did you pull the pin & remove it the right way?
Old 10-03-2012, 01:47 PM
GrandPrix's Avatar
Well being a dumb arse, I removed the screws because that looked easier. Now, I am figuring out that probably was the wrong thing to do.
Old 10-03-2012, 01:49 PM
GrandPrix's Avatar
PS
This forum is outstanding. So much useful info.
Old 10-03-2012, 02:06 PM
scope103's Avatar
You probably do have a problem vis-a-vis the VAF (though I'm not sure you needed to replace it; a loose connector alone would do it).
But what about the codes? You should always check them; your engine is asking for help. You ought to listen. http://www.ncttora.com/fsm/1990-1995...e/diagnosi.pdf
Old 10-04-2012, 07:08 AM
GrandPrix's Avatar
Well swapped out the MAF and it did the trick. Word of warning; don't unscrew the connector from the MAF. their is one very hard to see metal wire clip that holds the female connector to the male prongs. This is where I screwed up.
The check engine light is extinguished now as well.
bigjstang
08-25-2021 12:41 AM
MMA_Alex
25
04-18-2017 05:07 AM
colinmil
07-06-2015 04:03 PM
HRDC0R19
07-05-2015 06:43 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: Help 92 22RE won't start
