help!!! 4runner wont start
Old 06-14-2006, 11:48 AM
ichoc2's Avatar
i just got this 1991 4runner w/ 135k and a headgasket that was leaking.(a little antifreeze out of the exhaust). the car had just had a tune up before i got it(cap, rotor, plugs, timing belt). so i tear it down and replace the head gaskets and put it all back together and it fired right up. so i adjusted the timing and though i was good to go. this was all last week. the car has been sitting since then(took two 15 min. drives in it) and then i decided to drive it to work today and get almost here and the car just died. so while waiting for the tow truck driver are start trying to figure it out. here is what i got so far...
1. it has spark
2. it smells like it is getting gas(not a real noticable smell but a little)
3. pulled front cover off timing belt looks good
4. i have not been able to check compresion yet but there is no oil in the antifreeze and it does not look like there is any antifreeze in the oil.
5. cranks over( does not even try and start... i mean not at all)
so the question with out tearing the entire top end down again what is going to be my best option to look at when i get home.
thank you matt
Old 06-14-2006, 11:59 AM
95RunnerSR5's Avatar
mine just died for no reason also and it was the AFM but i had no spark...have a shop pull the codes on it
Old 06-14-2006, 12:55 PM
ichoc2's Avatar
any other options if i can not get it to a shop to read codes or a way that i can check the afm
thanks matt
Old 06-14-2006, 02:16 PM
ichoc2's Avatar
any body have any other ideas??????
Old 06-14-2006, 02:20 PM
celica's Avatar
read the codes at home with a paper clip. Search on how - there are lots of write ups on it. It is also in your haynes manual. Have you checked the connection to the AFM - is it still plugged in tight - if a HG was done recently then it could have been disconected
Old 06-14-2006, 02:29 PM
ichoc2's Avatar
i will check that, thank you. i thought it was plugged in i did not check it again though.
Old 06-14-2006, 02:32 PM
ZUK
ZUK's Avatar
thanks matt
That sure sounds like something very simple....something that should cost nothing...something overlooked. You did alot in that engine bay. Something ether worked loose or a wire got smashed when something was tightened up. Check the fuses near the battery. How about the connector that goes to the AFM?
Touch every connection that you had to contact when you did the HG job. It will be something that maybe you can visually see as the issue.
JF9243176
10-08-2017 04:21 AM
vasinvictor
01-20-2016 12:39 PM
torgeir
06-25-2015 05:26 AM
JF9243176
06-24-2015 04:53 AM
JaredL
06-16-2015 04:47 PM
Quick Reply: help!!! 4runner wont start
