HELP! 22RE hesitating/back firing - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-07-2009, 02:15 PM   #1 (permalink)
My 86 22RE truck doesnt like accelerating. This only happens once the truck is brought up to operating temperature, if I am a little enthusiastic with thego pedal, it starts hesitating, then bogs down from 2500RPM to about 1000 then backfires. If i drive without giving it too much gas and shift by 2500 RPM it does not cause a problem. Has new plugs/wires/cap/rotor
Thanks
__________________
FOR SALE! 1986 Pickup, 22RE, Regular Cab longbox SR5
Here is the posting : http://www.yotatech.com/f108/86-sr5-...ainted-197466/
Quote:
Originally Posted by Matt16 View Post
My truck catches fire when ever I turn a corner because I have a locker.
Yotapowa is offline
Old 11-07-2009, 02:52 PM   #2 (permalink)
Whats your timing at?...check to make sure your dizzy is advancing properly.
milehigheric is offline
Old 11-07-2009, 02:59 PM   #3 (permalink)
My99's Avatar
Send a message via AIM to My99
Did it do this before you changed the plugs & distributor? As Eric mentioned, sounds like a timing problem...
__________________
Kyle H
Current Yota: 86 4Runner - Daily Beater
My99 is offline
Old 11-07-2009, 10:51 PM   #4 (permalink)
No it did not do this before I changed the plugs, however It did not start doing it immediately after either
__________________
Yotapowa is offline
Old 11-08-2009, 02:48 AM   #5 (permalink)
Have you pulled the plugs to see what they look like? What plugs and leads are they?
Old 11-08-2009, 08:23 AM   #6 (permalink)
abecedarian's Avatar
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
Sounds to me like a vacuum leak or problem with the intake duct.
__________________
Quote:
Originally Posted by Junkers88 View Post
I went and looked at that Ford.... I can't tell if the vehicle was just abused or if domestic builders don't see the point in building something that will last and look good.
I'm going outside to hug my 4runner.
Quote:
Originally Posted by DeathCougar View Post
Abe so far has been spot on, 100% correct. As usual
Insomnia: it's a way of life.
abecedarian is offline
Old 11-08-2009, 08:44 AM   #7 (permalink)
03vrod's Avatar
Timing and vacuum both are great places to start.How's your idle alot of times the computer will raise the idle to keep the engine running if there's a vacuum leak.
03vrod is offline
Old 11-08-2009, 08:03 PM   #8 (permalink)
Quote:
22re's ECU's don't have the capability to adjust idle speeds.
__________________
Old 11-08-2009, 08:33 PM   #9 (permalink)
I would check plugs and timing first. My 87' 4runner 22re has an issue, I started it last week ran for a minute then quit. Not getting fuel, checked relay (good) so replace fuel pump. still no power to it??????? What would cause this? When I started it last week it was being jumped!
Thanks
awm3tm is offline
Old 11-09-2009, 04:34 AM   #10 (permalink)
03vrod's Avatar
Sorry I forgot.No IAC on the 22RE you have to manually adj the screw on the intake.Thanks abecedarian.
03vrod is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
