HELP 1986 22r engine trouble - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 08-31-2007, 08:02 PM   #1
Johnny Reb's Avatar
I PURCHASED A 86 4X4 WITH A 22R ENGINE. THE ENGINE IS HARD TO START BUT WHEN YOU GET IT GOING THERE IS ALMOST NO THROTTLE RESPONSE UNTIL YOU GET THE PEDAL HALF WAY TO THE FLOOR, the engine will idle (rough) but has no power to pull itself. I did a compression test and the #2 cylinder was only holding 90psi while the rest were between 130-140psi any ideas (I think I need the head reworked) I cannot afford to just throw parts at it Am I on the right track with the head or is it possibly the fuel system??
PLEASE HELP A POOR UNFORTUNATE NEWBIE
Johnny Reb is offline   Reply With Quote
Old 08-31-2007, 08:53 PM   #2
90 PSI in a cylinder is pretty bad. Next step would be to do a Leak Down test to see where all your compression is leaking from.
Barbarossa is offline   Reply With Quote
Old 09-01-2007, 05:17 AM   #3
Johnny Reb's Avatar
how do you do a leak down test and how do you tell where it is going
1985 22r pickup, no spark but engine cranks sandyota 84-85 Trucks & 4Runners 5 11-01-2016 03:20 PM
88 Pickup Transmission Swap mskalmus 86-95 Trucks & 4Runners 6 03-21-2016 12:41 PM
Need help 1986 truck air conditioner recharge nanhodges2733 86-95 Trucks & 4Runners 6 07-16-2015 09:12 AM
02 Tacoma temp gauge fluctuating and trans stopped working Poncho0206 95.5-2004 Tacomas & 96-2002 4Runners 3 07-10-2015 07:21 PM
help with 1986 pickup raiderhawks00 86-95 Trucks & 4Runners 2 07-08-2015 07:23 PM
Tags
1986, 22r, cylinder, engine, leak, motor, no, parts, psi, pull, responce, response, smogging, throttle, toyota, trouble
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
