heater core leaking
Old 01-22-2012, 03:53 PM
sinful's Avatar
heater core leaking
1989 pickup 22re
how hard is it to replace?
Old 01-22-2012, 03:54 PM
sinful's Avatar
passenger side floormat is soaked with water/coolant.
Old 01-22-2012, 05:07 PM
wyoming9's Avatar
Red face
It would depend on your idea of hard??
If it has AC it can get real interesting to say the least.
Not real hard in a technical sense but very time consuming
Old 01-22-2012, 05:12 PM
xxxtreme22r's Avatar
Make sure it's not the windshield seal or fender/doorjam seals. Mine gets that way too and it's not the heater core. Different body, but same concept. Rather common problem. Especially with the northern salt belt guys.
Old 01-22-2012, 08:05 PM
tacdawi's Avatar
+1 to time consuming. I think its a PITA and the tediousness of this job always frustrates me. My 2 cents though is make sure you are careful when putting the vent assembly stuff back together otherwise your heat/defrost adjustments will be off.
Old 01-22-2012, 08:39 PM
sinful's Avatar
the entire dash has to come off? oh noo ! i would probably just bypass the heater core then ! don't really need it where I live lol
xxxextreme22r, I'm pretty sure is from the cooling system since the water under the floormat is green with some red corrosive stuff on it (needs coolant flush already too hehe).....
Old 01-23-2012, 04:10 AM
shaeff's Avatar
There's a link in my signature, it's not really a DIY per se, but it does show you the steps you need to take.
Old 01-23-2012, 04:15 AM
lol, yup, that would be coolant then.
Old 01-23-2012, 04:53 AM
sinful's Avatar
shaeff, I did find your post when doing a search prior to posting. I just wasn't sure if it applied the same method for this 89 pickup 2wd with AC.
I'm finding out all our toyota pickups, 4runners, 2wd, 4wd are very similiar.
thanks for the info
Old 01-23-2012, 08:02 AM
shaeff's Avatar
thanks for the info
Yeah should be the same setup. Only difference is that yours has AC. You can wriggle the heater core ducting out sans removing the AC evaporator. It'll just take some finesse.
the1998sr5
15
07-14-2020 08:35 PM
94 Newbie
08-06-2015 10:33 AM
this_guy
07-31-2015 01:27 PM
jjrbus
07-19-2015 02:06 PM
msane99
07-17-2015 10:13 AM
Quick Reply: heater core leaking
