Heater Blowing COLD
Heater Blowing COLD
it just froze over outside and i could careless except for the fact that i cant defrost my windshield
I have a 95 4runner
the heater is blowing cold air
and i drove it for about 45 min the other night on the highway and off and it still isnt blowing hot. Any suggestions on what i can do to fix this problem. Or should i just take it to the shop?
I have a 95 4runner
got to move the little lever from the blue side over to the red side....
whats your antifreeze good for?
otherwise its I think there is a common problem with the linkage on the blue/red lever failing.
Originally Posted by tulsa_97SR5
is your engine getting up to normal temp or running cold? Could be the thermostat stuck open.
im not completely stupid when dealing with cars, but ive never dealt with the thermostat before
is this something i could fix myself if it is stuck open?
if the temp guage is showing it running cold, then the stat is probably stuck open. get a new one and install it, take a minute or two and check out www.4crawler.com . there are some good articles in there on heating issues.
lee
lee
No Heat
It won't be the fan clutch, mine is seized and I get great heat, way below freezing plus driving 70 mph. Won't be the t-stat either, after 45 min's of driving it'll be warm. If it isn't the heater control linkage, its probably a plugged heater core.
Originally Posted by Glenn
Thermostat stuck open. The engine will eventually warm up even if the t-stat is stuck open.
i just flushed my heater core it was plugged just take the line off the fitting in the ngine bay on the fire wall ans put a hose up to it and blast away a huge chunk of this black crap coame flin out and now my heat works great
Originally Posted by suprathepeg
How did you get to that? Did you have to take the whole dash apart or just the blovebox?
1 Post
mmmmmmmmmmmmmmmmm............
