Heated Oxygen Sensor help needed
Old 10-07-2008, 07:04 AM
jamnik's Avatar
4runner 1995
I have 4 wires,
Blue - ?
White - ?
2 Black - these are probably heater conection
Which one is signal?
Which one is mass?
I need to conect new sensor but wire colors are different
Old 10-07-2008, 01:18 PM
jamnik's Avatar
now a reply for my own post :p
Blue wire is signal
White one is mass
2 Black sensor heating
Old 07-13-2009, 08:17 PM
Faded's Avatar
Going through this myself right now...just curious as to what you mean by "White one is mass"?
Thank you for the post, BTW.
Old 07-13-2009, 08:30 PM
shftatsix's Avatar
if your replacing it with a bosch the two black wires (stock) will go to the two white ones (bosch), no polarity so it dont matter which way you hook it up. The blue one (stock) will go to black (bosch) and the white wire (stock) will go to the gray wire (bosch)
Old 07-13-2009, 08:43 PM
Faded's Avatar
I have a factory O2 sensor (BLU, WHT, BLK, BLK) and a truck from some dumb-a that cut the plug off the truck-side of the wiring harness... (BLK, BRN, WHT/RED, PNK/GRN).
Old 07-17-2009, 10:44 AM
shftatsix's Avatar
i found your answer sir
The pink/green might be tan/green and the yellow/red might be white/red, my crap is probably just old and faded
Old 07-18-2009, 08:49 PM
Faded's Avatar
Thank you for the pic, I appreciate your follow-up and I'm sure the next guy will too.
I've actually had it hooked up for a couple days now and I was able to get the info to hook it up right after searching here for a while.
Old 07-18-2009, 09:33 PM
iamsuperbleeder's Avatar
wow, wierd, my Bosch was easy to install... it plugged right in
I tried one of the universal ones like that first, but it didn't want to work for me, so I just got a direct replacement
Old 07-18-2009, 10:16 PM
nv4runner's Avatar
I'm guessing that mass means ground since the white is the ground wire.
Old 07-19-2009, 12:43 AM
abecedarian's Avatar
And if you're using a universal sensor, there's always the wiring diagram that comes in the box....
Old 07-19-2009, 12:59 AM
shftatsix's Avatar
he was asking about the truck side of the plug (pink, brown, yellow, black). the instructions that come in the box, Bosch at least, refers to the colored wires on the O2 side of the plug (blue, white, black, black)
BigArt70
06-30-2015 09:51 PM
94hiluxZE
06-22-2015 10:42 AM
LSUMatt1514
60
10-10-2003 12:30 PM
HALMAN
06-14-2002 09:02 PM
Quick Reply: Heated Oxygen Sensor help needed
