Headlights dim for fraction of a second
when I brake, when I turn on a turn signal, when I shift into reverse...
This just started overnight. The headlights dim noticeably for just a fraction of a second, then return to normal. Not a huge problem, but it's annoying and the fact that it just started doing this means that something's off. Battery is only a few months old and tests strong, and the alternator is charging according to my tester. Any thoughts on what to check?
First thing look for a loose belt or corroded battery terminals.
Colder Temps will cause charging issues.
Another thing to check is the wire coming off the B terminal of the alternator they get old and brittle and strands start to break.
I would maybe upgrade your ground cables if it has never been done.
Get much Snow I drag so much onto the floor it can`t help but get into the fuse block
Been kicking the fuse block I do with my big feet once in a while I will have electrical problems.
The volt meter moving isn't necessary a problem. Might ticks back and forth with my blinkers on or when turning on/off headlights but it does not affect anything else.
All my issues of dimming lights, dancing voltmeter and other issues (windows going up deadly slow) went away the second i started my truck after doing the "BIG THREE", but I did 3 more 8ga. grounds to motor, trans, frame. 4ga for the other 3. I used welding wire from tractor supply. Good price and pure copper, not copper clad aluminum.
