Headlight Wiring - Quick Help!
Old 03-14-2008, 07:56 AM
DJK-West's Avatar
I'm installing my HID right now and I am stumped.
The 9004 wiring that I know about is as follows, looking at the socket from the end where the bulb plugs into:
_ - _
ground low high
The driverside wiring is red/white, red/green, red/yellow.
The passenger side wiring is red/black, red/green, red/yellow.
I put a light tester on what I thought is low beam (+) red/white, on the passenger side, turn on the low beam and it comes on. I put the light tester on what I thought is high beam (+) red/green, throw on high beam, no light! I put the tester back on red/white and it comes on when high beams are activated!! WTF!!!! Then I tested the other side and I'm more confused! The wiring doesn't observe the conventional 9004 wiring. What's the deal?? Can anyone help? Is the headlight system common ground or common power?
Old 03-14-2008, 08:14 AM
eric-the-red's Avatar
They are on a switched ground circuit, the red/white and red/black are the +12V wires from the fuses. The red/green wires go through the switch to ground for the low beams, and the red/yellow are grounded for the high beams.
I have a wiring diagram from a 95 4Runner in pdf format, if you want a copy send me an email address.
Old 03-14-2008, 08:38 AM
DJK-West's Avatar
Thanks for the quick reply! I am kind of confuse now as to how I'm going to wire up the ballasts. Each ballast has a 12+ and a ground lead. Since everything is switchable ground how am I going to wire this system? The kit that I have didn't come with relays or any other sort of harness aside from just the ballast and bulbs.
Old 03-14-2008, 08:45 AM
DJK-West's Avatar
Hmmm now that I think about this, the only wires I need to use is the red/white (driverside) and red/black (passenger side). Ground the ballast to chasis. Then I can just tape up the red/green and red/yellows. I won't need them since I have a single Xenon system that I'm wiring up. Would this work?
jasonty
41
12-23-2018 01:00 PM
sanctfy
All Other Toyota Swaps
09-15-2015 02:52 PM
rushw
07-18-2015 01:46 PM
icentropy
07-14-2015 10:23 AM
Steven.m.paulk
07-13-2015 01:40 PM
Quick Reply: Headlight Wiring - Quick Help!
