Headlight Issues! - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 04-15-2007, 07:37 PM   #1 (permalink)
Headlight Issues!
Hey guys, this is more of a, "I can't get my damned front grille off!" problem. I have a 1993 4runner with the 9004 type headlight bulbs. I bought the car used off of someone in October, and the headlights in there were absolutely horrible for night time driving.
So, I bought a couple of higher powered bulbs to replace whatever I had in there, only to find that I couldn't get my front grille off. I can get all the clips off the top part of the grille, and I can get them somewhat detached on the bottom, but when it comes to pull it out, it seems as though its jammed on the bumper. I was yanking at this thing for a good hour, and couldn't get the bloody thing off.
I have a feeling that previous owner of the 4runner bumped into something, and it pushed the bumper so that the grille is now impossible to take off. Perhaps its a pain to get off in the first place, but I don't know about that... Any suggestions, or am I screwed?
goofboy1 is offline
Old 04-16-2007, 11:30 AM   #2 (permalink)
Jay351's Avatar
Send a message via MSN to Jay351
Im in the same boat as you... my grille is pretty much stuck.. or so it seems
__________________
91 Pickup - xcab - 5sp - 3.0 - SR5 - 4x4 - 250k |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs | Diff breather mod| Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |idler arm brace|hella E-codes| Marlin armor |SS IFS brace | %100 Amsoil synthetic
http://www.cardomain.com/ride/2572486
Jay351 is offline
Old 04-16-2007, 12:16 PM   #3 (permalink)
Brenjen's Avatar
I need to replace my headlight lens in my '95 4runner; I tried to get my grill off & I must say if you got the clips on top off without breaking anything....you got a heck of a lot further than me. I tried for a half hour & gave up when I began to get frustrated for fear of a grill replacement too instead of just a lens assembly.
__________________
'95 4Runner 3.0 Automatic bone stock; it's becoming a project slowly but surely, one part at a time
"If ye love wealth better than liberty, the tranquility of servitude than the animated contest of freedom, go from us in peace. We ask not your counsels or arms. Crouch down and lick the hands which feed you. May your chains sit lightly upon you, and may posterity forget that you were our countrymen!”
Brenjen is offline
Old 04-16-2007, 05:07 PM   #4 (permalink)
leebee's Avatar
looks like youre going to need to crawl underneath and remove the bumper to get any further. get busy with the pb blaster for a couple of days, it should come free then.
good luck.
lee
__________________
93 sr5 v6 auto, 4x4
Photos http://s866.photobucket.com/albums/a...albumview=grid
there are quite some attractive ladies on here with Toys. (compliments of ironmike)
ifsc 3(.0)
http://tlca.org
www.of4wd.com
www.sontt.com
leebee is online now
Old 04-16-2007, 06:26 PM   #5 (permalink)
SONOFA!
Well, I'll start hosing down those bolts with some WD40... they look pretty rusted. Is taking off the bumper hard for that vehicle? Any suggestions?
goofboy1 is offline
Old 04-16-2007, 06:40 PM   #6 (permalink)
Marc's Avatar
On my 91 I have to remove the turn signal assemblies to remove the grill.
__________________
'91 4Runner SR5 V6 4X4 Auto, A/C, 4.56, 31x10.5x15 Nokian Vatiiva Tires, Taurus fan (removed)
'90 4Runner SR5 V6 4X4 Auto, A/C, 4.56
V6 power with V8 fuel mileage
I've used Fram oil filters and dino oil in all my stuff for 30 years and never had trouble
I bet MOST people who say "swap in a 3.4" have NEVER changed any engine nevermind converting to a different type
Marc is offline
Old 04-16-2007, 08:59 PM   #7 (permalink)
mine comes right out, just gotta twist the top part outwards to clear the lip on the bottom that goes into the bumper. If you have 9004's you might even be able to get at em from in the engine compartment. I'm assuming someone swapped in the housings with the replaceable bulbs instead of the stock sealed beams?
MMA_Alex is offline
Old 04-16-2007, 10:47 PM   #8 (permalink)
Shoua's Avatar
I actually work at my local Toyota dealership (NOT as a salesman!) and I have done it before. You DON'T have to tear or break anything off, although it is guranteed you will break some of the clips. Your local Toyota dealership parts department should have a few of them in stock though. Okay, see those clips that hold the grille in place at the top? Well there are the same clips on the bottom side as well. They are also on the top and bottom of the headlight surrounds. Also you will need to pull off your corner light assemblies first. You push down on the top of the clip to disengage them (to get to the bottom ones you will need a long flathead screwdriver), and when they are all disengaged you can GENTLY pull the grille off (it comes off as a whole assembly with the headlight surrounds). If all else fails, you can use a long thin screwdriver to get to the three screws holding the headlamp in place. This sometimes works, but you might break more things. Hope this helps.
Shoua is offline
Old 04-18-2007, 11:01 AM   #9 (permalink)
Thanks for the info... turns out the previous owner got into a minor bump and actually bent the bumper brackets upwards. When this happened, it was pressed flat against the grille, and therefore, rendering it completely not removable.
I ended up removing the front bumper, salvaged the driver's side bracket, and ordered another passenger side one. Woot woot! New headlights make a helluva difference!
goofboy1 is offline
Old 04-18-2007, 11:20 AM   #10 (permalink)
rentedmule's Avatar
i changed my bulbs a few times and i never had to take the grill off. it was a while ago but i'm pretty sure i took the battery and airbox out and there was an access hole in either side of the rad support to get at the bulbs.
__________________
'93 4runner, 3.0, 31x10.5's, OME900's.
'84 Xtracab, 22R, flareside, 6" lift, 33x12.5's
'03 Sonoma 2wd, supercharged 4.3L@9psi
'81 Turbo Trans Am, WS6, 301V8@9psi
rentedmule is offline
Old 04-18-2007, 11:32 AM   #11 (permalink)
Seems like either way is a hassle.
The 92-95 4runners state in the owners manual that you need to take out the grille, then the headlight housing, then the bulb... in my case, my bumper, too! Haha...
goofboy1 is offline
Old 04-18-2007, 02:35 PM   #12 (permalink)
Brenjen's Avatar
"although it is guranteed you will break some of the clips"
Sorry Shoua, but NO that's not reassuring! LOL
My problem is those clips, I don't want to break them & I have to remove the grill to replace the head light assembly.
__________________
Brenjen is offline
Old 04-18-2007, 02:43 PM   #13 (permalink)
1989toy4wd's Avatar
Send a message via AIM to 1989toy4wd
In the instructions to replace the headlights you have to remove the bumper, thats why you cant get it out!! I do not know why toyota designed our trucks this way, its just a big hassle to change a freakin headlight!
__________________
-Colton-
1989 Toyota Pickup DLX, 22RE, 5-spd, 5-in SAS, Detroit back, ARB front, longs, 37/13R15 Boggers, Marlin front and rear bumpers, Marlin sliders, Ramsey Patriot 9500 winch with synthetic line, Hi-angle D/S F&R, diff breathers, rebuilt tranny, 22RE bored .20 over completely rebuilt (it feels great to not have to buy 2 cases of oil a month!!), whole truck built in memory of my dad (RIP 6-26-08)
Daily driver & tow vehicle: 02 Dodge 2500 Diesel, 5-speed, 4wd, quad cab, longbed, 128k miles
1989toy4wd is offline
Old 04-18-2007, 06:42 PM   #14 (permalink)
EZ headlight removal w/o removing grille...
...Is possible IF you're willing to grind a few small(.25" diameter max) notches in that chromed ring around the headlight, precisely at the locations where a screwdriver lines up with the removal screws. Digicam is in shop or I'd post a picture. It's really simple, and you can't see the notches from > than 10 feet away, and even then only if you're looking for them.
__________________
-KB-
'91 22RE Reg Cab, 4.56 w/31's, W56, BudBuilt Crossmember, Bilsteins, shell, TJM Channel bumper, otherwise stock. Engine rebuilt... Now not leaking anything.
Keith B. is offline
Old 04-18-2007, 08:43 PM   #15 (permalink)
Shoua's Avatar
Well, I said you are "guranteed you will break some of the clips" because we all know these trucks are getting old, and thus those small plastic clips get very brittle. I've taken grilles out before, WITHOUT removing the bumpers. The bottom clips (on the bottom of the grille, between the grille and the bumper) are the hardest to get to, like I said you can access them with a long flathead screwdriver. When you press down on the top of the clip it should go down and stay there. Then before you reinstall the grille you install all the clips into the grille first, then the whole assembly snaps back. Like I said, you can also try using a small long phillips screwdriver and bend it around the headlight surrounds to get to just the screws around the headlight assembly. I've done it both ways, and both times I broke some clips! D'oh!
Shoua is offline
Old 04-19-2007, 06:31 AM   #16 (permalink)
Brenjen's Avatar
I push in on the tops of the clips & it won't move lol & I refuse to break anything at this point. I'm stubborn enough that I will win & the clips will lose, I just hope they live on when I'm finished.
__________________
Brenjen is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Headlight Always ON maguirre 95.5-2004 Tacomas & 96-2002 4Runners 7 10-21-2007 12:47 PM
headlight ? 1987 street toy 95.5-2004 Tacomas & 96-2002 4Runners 3 01-14-2005 01:33 PM
headlight DRUMER77 95.5-2004 Tacomas & 96-2002 4Runners 5 06-27-2003 12:46 AM
Which Headlight, One Headlight .) Mossback74 95.5-2004 Tacomas & 96-2002 4Runners 10 02-09-2003 07:10 PM
2009 InternetBrands, Inc.
