Headlight Burnout
Old 06-14-2010, 08:40 PM
jay4runner's Avatar
Headlight Burnout
I have a 1990 4Runner. A while back my headlights started burning out way too often. I have had to replace the last few sets of headlights (sealed beams) every few months. One will burn out after a few months and then shortly thereafter the other will burn out. The high beams still work but I can't drive around with them all the time. The one time that I noticed when a bulb burned out it happened just moments after starting the vehicle (don't know if that means anything). Does anyone have any knowledge/suggestions on this problem. Thank you.
Old 06-14-2010, 09:44 PM
iamsuperbleeder's Avatar
have you tested the voltage at the light plugs?
too low, or even too high if you're vehicle's overcharging, can cause premature failure
what brand head lights are you using too?
Old 06-15-2010, 01:32 AM
drew303's Avatar
Where are you located? Cold weather tends to zap bulbs.
Old 06-15-2010, 03:33 AM
Fishaa's Avatar
Any moisture in the headlamp? A rock chipped a hole in mine once and as as soon as it got moisture in there it steamed up and blew the bulb. Had to replace the whole lamp (not cheap)
Old 06-15-2010, 05:21 PM
jay4runner's Avatar
I haven't checked the voltage. If it is off what sorts of things would cause that? have used a couple of different brands of lights - sylvania, ge
Old 06-15-2010, 05:54 PM
jay4runner's Avatar
Not cold here - west coast
Old 06-15-2010, 07:06 PM
well a faulty voltage regulator in the alternator could cause unusually high voltages, but you'de notice other problems too, like say, the battey boiling over, and the battery and brake like coming on in the dash
low voltages can be caused by bad wiring or bad ground connections
the bulbs are designed to operate at 12v, and usually a little more than that considering the average vehicle put's out around 14v while running
with the vehicle running and the head lights on (and plugged in mind you; as in the lights are lit up), you should probablt see 12.5-13 volts are the plug. I would go as far as to say that between 12v and 13.5 would be normal
yeah the Sulvania's should be good; I was just making sure you weren't replacing them repeatedly with some weird off-brand cheap-o light
Old 06-15-2010, 11:42 PM
wyoming9's Avatar
Red face
Interesting I would have to say it is a voltage problem to much or to little.
I drive with my headlights on all the time and only have the odd burnt out light once in a great while.
** One thing I do with all my Toyota vehicles is upgrade the ground cables one to the body and one to the engine block with number 1 welding cable. I know it helps with starting and charging issues.
Old 06-15-2010, 11:43 PM
Elton's Avatar
that will shorten the bulb life too
Old 06-16-2010, 05:15 AM
iselloil's Avatar
Bad Ground.
Old 06-16-2010, 05:18 AM
xxxtreme22r's Avatar
I had this problem after my last RC trip. Turned out it was a combo of a few things, I had moisture/mud in the headlight sockets which in turn led to a bad voltage regulator in the alternator.
Old 06-16-2010, 08:55 AM
studies do show it's safer though
apparently, even during the day, you've more visable with the headlights on. or at least other motorist see you sooner
that's why it's common practice now for the car manufacturers to put auto-lights on the vehicles that turn on when you put it in gear, regardless of the light outside
Old 06-16-2010, 09:04 AM
Sponsor
Tofer's Avatar
switch to an H4 housing with HIDs....
Old 06-16-2010, 09:36 AM
good idea as far as bulb life and visibility, but what about the ballasts that don't like severe changes in voltage.
Old 06-19-2010, 02:46 PM
jay4runner's Avatar
I have measured the voltage as follows...
When vehicle not running:
Across Battery - 12.5v (13.17 volts shortly after turning vehicle off)
When vehicle running:
Across Battery - 14.47v
At Headlight - 14.06v
Are these readings a problem?
Old 06-20-2010, 12:23 AM
wyoming9's Avatar
Red face
If I have reduced bulb life I have yet to notice.
What changed or what happened just before this started ??
Do you have any problems with any of the other bulbs besides the headlights??
Do you blow any of the headlight fuses ??
A loose connection that could cause a voltage spike perhaps??
While on the high end if your Meter is close it should not cause the problem.
I will do some checking
kawazx636
10-06-2021 03:03 PM
4banginRunner
11-13-2015 05:23 AM
mreagen
10-05-2015 04:27 PM
beltcutter
09-30-2015 06:14 AM
JPV
09-28-2015 03:15 PM
Quick Reply: Headlight Burnout
