headlight assembly
Old 06-05-2013, 07:49 PM
nacy369's Avatar
headlight assembly
pretty sure I am missing some stuff for my header panel. headlights are currently zip tied into place. Can some one tell me what I all need for my headlights? like housings bezels adjustment screws and what not and where to get order it. Ill try to snap a picture later.
Old 06-05-2013, 08:30 PM
Scrussanation's Avatar
i had that problem as well. JC whitney along with carid.com, autoanything.com, and streetsideauto.com had lots of what I needed... mines an 89 and this is some for those at jcwhitney. love the internet
http://www.jcwhitney.com/replacement...2183y1989g24j1
Old 06-05-2013, 08:32 PM
i even replaced my front plastic grille.. i believe jc whitney too... meant to tell ya its usually not in the lighting section but in the body and trim section... or exterior
Old 06-06-2013, 03:42 AM
nacy369's Avatar
its impossible to find a complete headlight assembly. I really need to find the adjustment screws.
Old 06-06-2013, 03:54 AM
did you not check those?? i bought one for mine so why are you not finding it??
Old 06-06-2013, 04:03 AM
I'm assuming not... I'll make this so easy for you its insane....
http://www.jcwhitney.com/dorman-univ...83y1989g24u0j1
now you can jump around and say especially when
Old 06-06-2013, 07:53 AM
nacy369's Avatar
Ill just take some pics on friday so anyone can pipe in and tell me what I need. Its a salvage title so she needs alot of work.
Old 06-06-2013, 08:02 AM
is what I provided not what you need? it has all the houseings and even the screws....
Old 06-06-2013, 08:21 AM
nacy369's Avatar
It just showed up with retaining clips?
Old 06-06-2013, 08:29 AM
if you look below the clips you will see a selection of headlight retaining rings.. those come with the 4 screws that hold in the sealed bulb. thats what u needed right?? u cant just get the screw alone and most likely the old retaining rings are gonna be bent out of shape on yours anyways correct me if im wrong
Old 07-27-2021, 08:25 AM
jazz1's Avatar
Old thread but what size are the screws holding headlight retaining ring? Searched but can't come up with a metric size,,,only seeing 8 32 1/2"
Old 08-04-2021, 07:56 PM
coopster's Avatar
Location: exo-reality -wave if you see me; Front Range, CO
thread size
You should've started a new thread. This probably wasn't seen.
But here is a thread with your answers and more.
https://www.yotatech.com/forums/f116...ersion-313818/
02-15-2024 05:44 PM
YotaBruce
08-12-2013 08:17 AM
Jason B
9
09-26-2006 05:34 AM
Deathmage
16
02-08-2006 10:32 AM
Quick Reply: headlight assembly
