headbolts
Sure....
These FSM instructions will walk you thought the process.
You'll also need a 12 point 12mm socket.
I just made a "specialty tool" to help me compress the springs while leaving me enough room to remove the valve keepers. I put the head on the deck of my shop press, put my home-made specialty tool on, used the press to compress the spring, popped the keepers out and took the pressure off the spring. Very easy to make... and very easy to use. You need a press to do it that way, though.
