Head Or Timing Chain First?
Old 10-26-2011, 10:08 PM
Jonzzer's Avatar
Well i was only planning on doing the timingchain but chewed up the headgasket on the top of the Tchain cover so get to so the whole thing right now its just the block heads of so is tchain... My question is what should i put together first, put the new timing chain set in? or the headgasket. Right now im thinking the timing cahin first ,but Im a little worried that if i put the timing cover back together before the head that it will be out of alignment when i put the head and cam back together...but dont wanna chew up another headgasket if i do the opposite... So what do all of you yota Guru's advise???
Old 10-26-2011, 10:17 PM
Fossilized
Staff
dropzone's Avatar
Download the FSM from the link in my sig.
Old 10-26-2011, 10:34 PM
fork's Avatar
if you plan on doing the headgasket anyway, it's a lot easier to install the timing cover with the head off. however if you don't plan on changing the cover you can get away with slipping the cover under the head and trying not to mangle the head gasket. OR you can do crazy things like I did -- nip the head gasket flush with the block if you've already mangled it, and seal the large gap with some toyota seal packing. i'm not recommending you do this, and i take no responsibility for what happens. it's more of a last resort
Old 10-27-2011, 02:05 AM
92 TOY's Avatar
see below
this^^^
if you are gonna do the job...do it once, do it right. "THREAD B" in my sig is my adventure as a newbie novice. If I could do it, anyone could do it.
Old 10-27-2011, 10:14 AM
Jonzzer's Avatar
Hey 92 Toy Wow that is the best newbie help right there, The FSM always leave you guessing a bit. Luckily im doing it the easy way i have the motor out on a stand. I think ill do it the way you did, timing cover first then the head. How did you get the crank sprocket off, did you use a tool?
Old 10-27-2011, 01:05 PM
92 TOY's Avatar
nope....Ihave some pretty good pics of how to do it...but it was still in the truck
Old 10-27-2011, 01:18 PM
SCToy's Avatar
Timing cover first, then head. The link in my signature has some pics and chef did an awesome job pointing me in the right direction. I did it in the truck though.
bigjstang
08-25-2021 12:41 AM
Colington
03-08-2020 09:51 AM
smiley52
07-11-2015 05:16 AM
Quick Reply: Head Or Timing Chain First?
