Head lights problem
Old 07-29-2014, 03:46 AM
Crazy_Guy97's Avatar
Head lights problem
Why does my head lights go really dim when im doing bout 20 mph . In a 1986 toyota 4x4 i have the tail lights unhooked.
Old 07-29-2014, 04:19 AM
JasonYota's Avatar
Headlights go really what? Please look over your post before you submit it
Old 07-29-2014, 05:04 AM
kcaudill's Avatar
I assume DIM?
Old 07-29-2014, 05:58 AM
AdmiralYoda's Avatar
At least his tail lights are unhooked. For a second I was worried and thought his glovebox bulb might have been bad.
Old 07-29-2014, 12:27 PM
Yea dim then almost off then back on and so on
Old 07-29-2014, 02:01 PM
RAD4Runner's Avatar
You only have a problem at 20 MPH? then drive faster - LOL!
How about other speeds?
Checked your alternator voltage? Use this:
Amazon.com: Neewer® Mini 12V/24V LED Display Digital Car Volt Meter Vehicle Voltage Gauge: Industrial & Scientific Amazon.com: Neewer® Mini 12V/24V LED Display Digital Car Volt Meter Vehicle Voltage Gauge: Industrial & Scientific
Old 07-29-2014, 05:00 PM
And higher speeds still does it.
Old 08-04-2014, 01:23 AM
RSR
RSR's Avatar
Try an auxiliary harness. Outlined here in several threads.
Old 08-07-2014, 02:42 PM
What is that?
Old 08-08-2014, 10:40 PM
RSR
RSR's Avatar
It routes power directly from your battery to your lights rather than going through the switch... All the swtich does after install is activate the relays.
https://www.yotatech.com/forums/f131.../#post52106589
Old 08-09-2014, 06:25 AM
Shoua's Avatar
I had the same problem.
Mine ended up being the contacts in the alternator were WAY worn out. Replaced it, now mine's fine.
Old 08-10-2014, 12:15 PM
So I need to replace the alternator?
Charecter1
11-06-2023 10:08 AM
ashersullivan88yota
01-18-2022 05:37 PM
06-01-2021 01:51 PM
Huntingtruckcletus
07-08-2015 05:26 PM
colinmil
07-06-2015 04:03 PM
Quick Reply: Head lights problem
