Head Gasket set Identification.. plese look 22re 1986 4wd
Hi i recently bought a complete head gasket set and I need some help dentifying the parts, they
are already numberd just want to know where each one pertains to,, thatnks alot,,,
here are the pics
here are the pics
dude thats alot of help you will see where they go when you start tearing down many of those gaskets don't even go on your rig. also you numbered the same gaskets twice.
but here is a start
1 oil pump oring
2 water pump
3 carburator heater you don't have
head gasket only goes on one way
4 throttle body
5 throttle body
6 intake plenum
7 v6 water passage not on your rig
8and 9 fuel pump
10air injection valve
18 valve cover baffle
19 egr to plenum
20 egr on a carbed motor
21 and 22 are exhaust air tube gaskets on a carbed
23 and 24 are air tube to ex manifold
25 oil pump pickup tube
26intake gasket
27 air tube
28 distributor
29 thermostat
30 injector to rail
good luck
but here is a start
1 oil pump oring
2 water pump
4 throttle body
5 throttle body
6 intake plenum
8and 9 fuel pump
19 egr to plenum
26intake gasket
27 air tube
28 distributor
29 thermostat
30 injector to rail
good luck
06-01-2021 01:51 PM
