head gasket?
head gasket?
i started my truck up the other day and i noticed white smoke was coming from the exhaust pipe, not to much though, and when i revved it a little this black liquid spewed out. so what i am wondering is could this be my head gasket and how can i check to see if it is? thanks
Do a coolant leak-down test; a mechanic can do it or you can just go to Sears & buy the kit for about what they'd charge you. It's the ONLY reliable test for HG.
Another indicator is a slight loss in coolant... It can go out the exaust pipe or down in the oil pan. If it goes into the oil, it's going to sit at the bottom, you can try draining a little bit out to see if you have water.
Exhaust system does get condensation in it.. Some water coming out on cold start is normal.
Exhaust that smells sweet is not normal.
White smoke on start-up may just be the condensation. If it continues while driving, then you may have a problem. The smell will tell. (Was that too corny?..hehehe)
Gee, guy....if you're only getting white smoke and black spew on start up, then all you're dealing with is condensation and carbon from exhaust mixing with it. Quite, quite normal. It is possible you're running a tad rich, though. Have a look at your spark plugs.
Prior to that, she'd be a smoke machine until it warmed up, then no smoke at all....
kgcwb44
01-29-2023 10:02 AM
the1998sr5
15
07-14-2020 08:35 PM
09-04-2015 09:27 AM
themightykhoner
08-11-2015 07:37 PM
