Have a stock height 87/88 4x4 you can measure ???
If someone would be able to measure a rear reference point on a stock height 87 or 88 4x4 truck I would appreciate it. Some reference point on the frame behind the rear tires would work fine. I cannot find a measurement that makes sense anywhere. If it matters mine is a single cab short bed but I will take anything . Would be happy to give a cell number if you can text a pic of the refrence point and how I Sits.
Thanks !
Z
Thanks !
Z
I really just want a point of refrence. I have a flat bed in mine so it is hard o tell how much it is sagging. I can fab some stuff but would really like to know the starting point for the stock suspension.
I got 24 1/4" from ground up to bottom of frame rail directly behind the rear spring shackle. 20 1/2" from the ground up to the bottom of the frame rail directly behind the front tow hook (front). Stock 213K mile '88 4Runner with 31" tires.
Thanks bro. I guess I can complain. I am on 28" tires with 25 1/2" rear and 20 3/4" front to where you measured! Not sure what to do about that!
Thanks for the info though!
Z
Z
Flying91
45
04-11-2024 04:39 PM
