| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
have some ign. timing issues. . . .
#2 (permalink) | |
Quote:
You are checking your timing correctly, but make sure that your p/u is on the #1 s.plug wire, your jumper should be on "te" & "e1", now to check your code just leave the jumper in place with just the ignition on look on your dash and it should flash you a code. For example: 2 flashes followed by a short pause and another flash would indicate a code 21, there will be a long pause and it will go onto another code or repeat the previous one. If it flashes real fast no codes. To clear the code pull a battery cable off for a minute or pull the efi fuse. Your code is caused by your timing advancing or retarding to much! I read that this 3.0 was rebuilt, it almost sounds like your Timing belt might be off a tooth or two or it's the wrong belt, either case if your t-belt is stretched, off a toothe or too big of a belt it will jump time like you described! To make sure your close to time, get your #1 cylinder to TDC, take your distributor cap off your rotor should be pointing to the #1 cylinder, by doing this once you put your T-light back on she should be real close to time. Good Luck!
__________________
The Master Toyota Tech, 2003 Toyota Tacoma xtra-cab, 3.4 V6, 5speed,4x4, TRD w/OffRoad Package. "Expert on the 3.0 Engine!" Disclaimer: As a former TOYOTA TECHNICIAN I authorize this post/reply US MARINE*** SEMPER FI |
#3 (permalink) |
Thanks for the input. Now that I'm back from vacation I have a chance to mess whith it. The timing belt is brand new. I made absolutely sure the marks were all lined up properly before I put it the rest of the way together. I did notice something strange, though. . . . . when i set the ignition timing, I jumped then connector, set it at 10*, then removed the connector and noticed that its still at 10*. Seems like jumping the connector made no difference to the timing. This doesn't seem right, does it?
#4 (permalink) |
Since I did this myself, I'll give the answer again. It sounds like your TPS is out of adjustment. See here: http://www.yotatech.com/showthread.php?t=79788
__________________
94 4runner SR5, V6 3VZE, 5 speed Completely rebuilt engine with Toyota parts at 147k miles Downey Coils, Aisin manual hubs, Cowl Louver mod, Hella 500 fog lights Yeah, I know, not many cool mods here |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Timing issues | mytoy | Newbie Tech Section | 13 | 07-16-2007 11:59 AM |
| Timing Chain Issues | cweich | 86-95 Trucks & 4Runners | 2 | 05-03-2007 07:55 PM |
| timing issues | tampabayota | 86-95 Trucks & 4Runners | 5 | 02-12-2007 11:41 AM |
| 22RE Timing Issues! | SupraSport | 86-95 Trucks & 4Runners | 23 | 01-28-2007 02:04 PM |
| Timing issues... | MarkH1121 | 86-95 Trucks & 4Runners | 8 | 12-05-2006 10:03 AM |
