Have to replace false fan pulley bracket, is this what I need?
So my '92 3.0 cooked the fan pulley bracket bearing thing.
I'm not looking forward to this job
I hear aisin is best so is this what I need?
LINK FIXED!!!!
LINK FIXED
Thanks guys!
LINK FIXED!!!!
LINK FIXED
Thanks guys!
I get nothing on that link.
They're difficult to come by without paying full price, which is SIGNIFICANT. If you can find one from a pick & pull that's in good shape, I recommend that. Aftermarket brands are subject to failure from what I hear.
I put a little motor oil around the bearing on mine whenever I have it out & let it soak in over a couple of hours. Extends the life greatly~
I have been using a cheap ebay unit I bought years ago and it is still going strong. I did go for an autowrecker unit before that was in good shape, but that siezed up in a MacDonald's drive through one day.
http://www.autozone.com/autozone/par...er=898128_0_0_
I just replaced mine not too long ago, 115$ at autozone.
I was looking for the aisin because if it is better quality, then I would have to do this job less often hopefully.
No issues outta mine thus far, with anything you buy, there will always be some that slip past quality control. I would venture it a lot better idea than used from a pic n pull.
AISIN FBT-006..... yes, that is it in your first link.
For future reference:
http://www.aisinaftermarket.com/PDF_...erenceList.pdf
IIRC, you cant press out the bearing... There really is no "bearing" Its just the shaft thru the housing, and tapered rollers on the inside, I did manage to press the shaft out, than all the little rollers fell out, and I realized it was not something that could be repaired, and needed to be replaced.
Back when mine seized, autozone did not carry them, and I couldnt find after market ones anywhere... I ended up paying the $700+ the dealer wanted. I would gladly have paid $115 for 1 even if it only lasted a year... the one I paid $700 for only lasted 6 years
Thanks all
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
09-09-2015 06:24 AM
jon.r
07-11-2015 03:34 PM
