Has anyone done the 22RE-to-V6 conversion? - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 02-15-2009, 09:41 PM   #1
HiLuxer's Avatar
I know it sounds weird. But I have decided to do it. My truck has a strong 22RE with good trans but the frame is too rusty. I found a donor truck, which is a V6 truck but no motor/trans. I'm going to do the swap pretty soon but need some more info on that. I know that the motor mount location is different. Is it too difficult to relocate them? The most of the conversion has been done by the PO (fuel line, pump, rear end, etc.). Is there anything else I need to be aware of? Thanks for all the input guys.
HiLuxer is offline   Reply With Quote
Old 02-15-2009, 09:44 PM   #2
904_runner's Avatar
wait are you going to put the 22re into the truck that originally had the v6?
Im sure someone has done this
904_runner is offline   Reply With Quote
Old 02-15-2009, 09:45 PM   #3
totally a bro
Staff
vital22re's Avatar
find a 5spd tranny and matching transfer case for the v6 from a v6 and swap in the 3.4 into the v6 truck. Its an awsome swap and i've got the 3.4 in 92 and love it!
vital22re is offline   Reply With Quote
Old 02-15-2009, 09:46 PM   #4
HiLuxer's Avatar
Yes, the topic is kinda confusing.
I tried the search engine but not that I could find anything about the motor mount relocation.
Old 02-15-2009, 09:49 PM   #5
HiLuxer's Avatar
Quote:
I know but I already have a solid 22RE motor w/ the tranny. I just needed a solid truck, which happened to be a motorless V6 truck for cheap. I also don't have a lot of $$ to spend at this time either.
Old 02-15-2009, 09:51 PM   #6
904_runner's Avatar
You will have to fab up the motor mounts, teh crossmember, are both truckst the same type of transmission?
Thats a given, plus all the other hidden problems you encounter.
Old 02-15-2009, 10:28 PM   #7
HiLuxer's Avatar
Yes, they do have 5spd. Thanks for the input. Any link for the motor mounts fab up?
Old 02-15-2009, 10:31 PM   #8
91Toyota's Avatar
Nope never been done. You will clearly be the first ever.
91Toyota is offline   Reply With Quote
Old 02-16-2009, 06:45 AM   #9
toyminator2000's Avatar
Motor mounts on the v6 truck frame are about 1" farther back than the 4cyl ones so you may need to cut them off and relocate them.
toyminator2000 is offline   Reply With Quote
Old 02-16-2009, 07:52 AM   #10
HiLuxer's Avatar
Quote:
Well, looking forward to... LOL
Old 02-16-2009, 07:53 AM   #11
HiLuxer's Avatar
Quote:
Thanks. I knew that I would need a good welder for this job since I am not.
Old 02-16-2009, 10:10 AM   #12
mt_goat's Avatar
mt_goat is offline   Reply With Quote
Just Differentials Toyota Tundra Crewmax w/ 6.5' bed justdifferentials Vendors Build-Ups (Build-Up Section) 13 01-18-2017 04:04 PM
Distance vertically between oil pan and highest part of axle housing? live4soccer7 84-85 Trucks & 4Runners 3 05-11-2016 07:52 PM
3rd gen possible efan conversion runnermedic 95.5-2004 Tacomas & 96-2002 4Runners 13 09-21-2015 06:20 PM
22R idle is surging with AC on Gurr 84-85 Trucks & 4Runners 2 09-12-2015 10:51 PM
Tags
22re, 2557517, 30, 4runner, bar, conversion, conversions, convert, cyl, engine, mount, swap, torsion, toyota, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
