Harmonic balancer installer for a 3VZE?
Old 05-04-2012, 06:55 AM
zooki's Avatar
What are you guys using to install the harmonic balancer on a 3VZE motor? I rented a balancer installer from AutoZone, but it doesn't have the correct adapter to fit the crank. As far as I can tell, it's a 16x1.5mm bolt, which isn't very common. I have looked online, and all the installers come with a 16x2.0mm adapter. Any suggestions?
Old 05-04-2012, 06:58 AM
93toyrunner2's Avatar
Install the harmonic balancer, use your hands. It should slide right on. Rubber mallet for some light persuading!
Old 05-04-2012, 07:23 AM
Marc's Avatar
I just used the balancer bolt to put it on.
I used fine emory cloth to clean the crank and balancer first.
Old 05-04-2012, 07:43 AM
92 TOY's Avatar
that^^^ yes. make sure the surfaces are clean and perfect
Old 05-04-2012, 07:52 AM
scope103's Avatar
Remember that there is a woodruff key (half-moon shaped, that fits into an arced slot). If the key rotates in the slot, it can jam the balancer (this is usually only a problem when removing it.)
As others have said, it is a sliding fit, so you should need nothing other than your hands to slide it on. Not even a rubber mallet.
clok
08-01-2015 09:42 PM
91yotapup
07-27-2015 07:19 AM
dropzone
07-16-2015 02:00 PM
smiley52
07-11-2015 05:16 AM
Quick Reply: Harmonic balancer installer for a 3VZE?
