hard start/fuel in vacuum lines
Old 02-01-2011, 05:08 PM
SDHNTR's Avatar
88 4 runner, 22re.
I have a hard start issue. To get the truck to start and stay running I have to hit the pedal a time or two. It also cranks for a long time too. Once up and running it seems fine and runs great, only happens at start and it's worse when cold. Attempting to trace the issue, I pulled a couple vacuum lines and found fuel in the one coming off the fuel pressure regulator. I know that isn't right so it is probably toast. That makes sense doesn't it? Would this cause my hard start issue? Just wanted to get another opinion before I drop $100+ on the part.
All ignition parts are new. Fuel injectors are new. All sensors have been checked and TPS slightly adjusted.
Old 02-01-2011, 05:13 PM
xxxtreme22r's Avatar
either way your not wasting the $100 for the regulator. Also research CSI or cold start injector.
Old 02-01-2011, 05:17 PM
SDHNTR's Avatar
Tested the cold start injector cold and hot, all good there.
Old 02-01-2011, 05:24 PM
Kiroshu's Avatar
A leaking diphram in a Fuel pressure Regulator will cause cold starting issues as unmetered fuel is being pulled into the intake flooding the engine with fuel. The same issue with a leaking Cold start injector. I would recommend you change the FPR.
Old 02-01-2011, 05:26 PM
SDHNTR's Avatar
I think that is the next step. Anything tricky to changing one out? Looks like I will need to remove the EGR pipe first.
Old 02-02-2011, 06:14 PM
SDHNTR's Avatar
Pulled the old FPR today. The top of it (where the vac line is) was full of fuel. It's shot right?
Old 02-02-2011, 06:22 PM
bugs1961's Avatar
Yep. Diaphragm is broken and causing the problems described above by Kiroshu.
Tacoma1313
08-17-2015 05:44 PM
Poppie51
07-23-2015 05:03 PM
Poppie51
07-16-2015 06:16 PM
jgwerth
07-16-2015 03:23 PM
TokyoD23
07-12-2015 06:01 AM
Quick Reply: hard start/fuel in vacuum lines
