Hard to get into gear slave cylinder replaced
so I just replaced my master and slave cylinder without a hitch. bench bled then installed and bled like I do my brakes. only problem is I cant get into gear unless I press real hard on my shift knob. I looked under and it looks like the slave cylinder is moving all the way properly. is this a clutch problem or did I just do something wrong with the hydraulics.
well after I posted this I look at similar threads. turns out I just didn't adjust the push rod properly.... or at all. so I would of had to push the peddle below the floor to disengage the clutch all the way. so 12mm wrench and some finger work later its perfect.
