H4 Conversion Product Question
I am looking to get rid of the ridiculous stock headlights...
So, looking at H4 conversions, what should I look for?
What would be my best option?
Alex
Alex
Theres a thread called "H4 conversion" or something liek that.
Hella E codes, 200mm. Its what most people use, go look for that thread. H4s are way better then stock. well even the lens is amazing.
I have looked around at this a bit... Seems like quite a bit of work that I am not interested in doing to get rid of the "HID glare"
If I were a bit more advanced with lighting, I would go for that though. Looks REALLY nice when done right.
Alex
Everyone Else--
Thank you, I will look for the thread.
Alex
Everyone Else--
If you're asking about which H4 conversion kit to get to replace the stock sealed beams you basically have three choices...
Hella or Bosch E-codes are the best with Hellas being slightly better... the bosch ones are getting harder to find but are/were available from Canadian Tire.
You're other choice is APC's clear lens version with "diamond faceted reflector". This is the common "e-bay lens" and is not a good option for a basic or normal HID conversion because the reflector surface does a poor job of focusing the light on the road IMO. If you are planning on a projector conversion then your results might be different.
I swapped to the Hella E-codes right after buying my 4Runner. Best money I've spent. Using the GE Nighthawk lightbulbs and the lighting blows away any sealed beams I've ever tried.
r3dfish
54
05-16-2016 10:31 PM
