Greasing Slip Yoke
Old 04-28-2010, 04:44 PM
az4x4runner's Avatar
Greasing Slip Yoke
Lubing my drive shafts today, noticed that when I tried to lube the slip yoke on the rear drive shaft, I didn't see the slip yoke extend at all when pumping the grease in. Instead it started oozing grease from the inside the u-joint. Do I have a clog somewhere so the grease is not getting where it needs to go?
Old 04-28-2010, 09:45 PM
Jay351's Avatar
The slip yoke shouldn't extend when you're greasing it.. Grease won't lift the truck up.
Old 04-28-2010, 11:33 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
It does on mine. A little bit, anyway.
Old 04-28-2010, 11:49 PM
Jay351's Avatar
never noticed it on mine....
Old 04-29-2010, 12:02 AM
Yeah, they do ever so slightly. Is it normal for it to push some grease out toward the inside of the u-joint though? I hadn't noticed that before.. maybe it's full already. Just was out in the woods recently and the creek crossings are flowing good and deep from snow runoff, figured I'd grease em up again.
Old 04-29-2010, 03:01 PM
Well this is weird. I was at the store today and in the parking lot hit a speed bump, when the rear wheels went over it, I heard a clunk. First thought that came to mind was my slip yoke, and that maybe it was stuck/sticking. Well, after the clunk, I got home, tried lubing it again and this time it extended with the grease like it should.
Old 04-29-2010, 07:17 PM
Originally Posted by Gnarly4X
Yes, the slip joint will move (extend) when you pump grease into the zerk.
az... sounds like the slip joint was stuck or bound up, or full of little gravel.
That joint needs to "slip".
Yeah, always seen em extend before. All seems well now, guess that speed bump loosened it up. I'll keep an eye on it.
Old 04-29-2010, 07:43 PM
desertcamper67's Avatar
There is a cap on the yoke that holds the grease in. (on mine anyways) That cap can fall off as it did on one of mine in the past. It was then an opening that didn't hold any grease pressure so it wouldn't allow grease to travel up into the slip area when I greased it. Also allowed grit and contaminants to get in there.
Old 04-29-2010, 07:46 PM
Interesting.. wonder if my truck has/had one. Any idea where I might find a replacement? Or if anyone knows this parts name so I can try and locate one that way.
Old 04-30-2010, 05:14 AM
thook's Avatar
Yeah, be careful with that cap if you ever pull the slip joint apart. My '92 has one, but the '86 doesn't. So, one day a while back I decided to pull the joint apart on the '92 and the cap came apart. It's sort of fastened onto the end of the splines integrating into the splines. Don't know how else to really describe it. Needless to say, it was ruined and I to replaced the drive shaft with one that didn't have the cap.
I don't really what to suggest as far as servicing it. I do know that grease always comes out of the end (on both vehicles) into the u-joint as you've described. All my components work as they should, though, so I've considered it normal......hehe. Don't know how helpful anyone would be at a dealership, either. When I'd asked around about the "cap", everyone was clueless.
Old 04-30-2010, 06:43 AM
I suppose I'll just keep an eye/ear on things. It seems to be functioning normal now. I've seen that clueless look you speak of at the dealership before.. probably won't bother with them unless I have to...
justdifferentials
Just Differentials
06-13-2022 07:40 PM
kawazx636
10-06-2021 03:03 PM
ladybugRC
458
08-21-2020 10:41 AM
camel_65@hotmail.com
10-03-2018 06:11 AM
93toyoguy
3.4 Swaps
10
09-18-2015 04:16 PM
Quick Reply: Greasing Slip Yoke
