Got stuck tonight:(
Got stuck tonight:(
Yeah I know...it happens.
Anyway, went down a trail and basically I bottomed out on every tree I ran over so I decided instead of backing up (couldn't reverse) to go down a pretty steep embankment and get back on the road. I decided to chance it
I went front first and I could barely fit between some trees. I needed to turn left but ended up hitting a stump. Tried to reverse and you know how that goes with a 2wd in reverse uphill. Needless to say I dug for a couple hours and went back and forth for awhile until a couple drunk hooligans came from nowhere in a suburban and helped me push it uphill a little (in reverse) then I had to literally jump most of the stump. And I got out. I took some pics but it will be a little before I can get them up.
I'm thinking my senior project will be a 2wd to 4x4 SAS
Or I just need to bring a shovel, come a long, and a chain
2wd to 4wd isn't as easy as it sounds.
...but knock yerself out.
If you're 'silly' enough to take a 2wd truck out without at least another truck to help... well, 'nough said.
personally, I think the come-along, shovel and chain... though more work, will do you more good.
...and it's something you can use on the 4wd too.
Haha...thanks guys. I usually do all my fun by myself...and am even ballsier when I have other people with me
Anyway, a locker or a limited slip?
haha props for the Rally factor... my friend used to have a 2wd 4banger Ranger that we use to put thought its paces and hell there was even one time we out bogged a couple chevys on 35s.. enough momentum a big enough balls you can do almost anything .........P.S. put the comealong shovel and tow strap in there now..hell i dont even drive to the grocery store with out em.
before all-terrains...
and after the all-terrains...
yeah, we still ended up like this a lot too...
oh the good ol days before I even got my Yote... that's me stand'n there in the passenger doorway just thinking to myself "what the hell where you thinkin". He's quoted in this picture by many to be "wishing for his jesus to come down and un-stuck him", lol
4WD on a 2WD truck is almost as easy as an SAS is on a 4by. You just need a few extra parts to make it work right like a 4x4 rear axle, transmission, transfer case, drive shaft etc. I've seen it done.
For the way you use your truck I'd definitely throw a lunchbox locker in the rear. You'll be shocked at how much better it performs and it's cheap.
