Got new Muffler- how do I remove the rusty bolts?
Old 02-02-2006, 06:06 AM
CILO's Avatar
Hi everybody,
just recently got my replacement muffler (stock from toyota) and when i crawled under to take a look at the old one i noticed the bolts connecting the muffler pipe to the cat pipe are rusted soo bad that i dont even see the threads on the bolt on the other side. How does one go about taking out a bolt like this w/out having to pull out the sawzall?
Old 02-02-2006, 06:08 AM
Rivalred's Avatar
Soak it in some PB Blaster for a day or 2, or even before that try to heat it up with a small hand torch.....
Old 02-02-2006, 07:23 AM
eric-the-red's Avatar
If it's a bolt and nut then just break them, and get new ones. If it's a stud attached to one side of the flange then use the PB blaster and heat, and hope you don't break them.
Old 02-02-2006, 01:05 PM
trythis's Avatar
I used a 4 1/2 inch angle grinder and cut mine off, then bought some stainless ones to replace them. You might try that.
Old 02-02-2006, 02:59 PM
celica's Avatar
X2 - grinders are your friends
Old 02-02-2006, 03:02 PM
89macrunner's Avatar
spit is your friend!
accualy i would try what everyone else reccomends...or you could do the poor mans way like me and use your dremel to cut off your VERY rusted out running board bolts (that took a long time and a lot of those little cut off wheels)
Old 02-02-2006, 03:21 PM
Elton's Avatar
just cut them off and get new ones
Old 02-03-2006, 06:20 AM
celica's Avatar
HAhA - I tried the dremel once on a small bolt - after breaking two of those little wheels I gave up and got out the real grinder. I know what ya mean man.
Old 02-03-2006, 10:54 AM
surf4runner's Avatar
jasonty
41
12-23-2018 01:00 PM
jashoeuh
11-26-2017 07:01 AM
accuracy
08-06-2015 12:32 PM
TJWilly
07-31-2015 02:05 PM
Snort
07-09-2015 03:58 PM
Quick Reply: Got new Muffler- how do I remove the rusty bolts?
