Good spot to tap into efi for kill switch...
Old 03-29-2007, 02:53 PM
Kaleb's Avatar
I want to install a kill switch. Just wondering where a good spot to tap into the EFI is. I tried to go through the fuse box, but after an hour of fiddling with it I decided to ask you guys instead.
By the way I have a 1994 4Runner with a 3.0
Old 03-29-2007, 02:57 PM
Mark in MD's Avatar
Why do you have to tap into the EFI?
Here's an idea:
https://www.yotatech.com/forums/show...ht=kill+switch
search around, you might find more
Old 03-29-2007, 08:06 PM
toyota_mdt_tech's Avatar
EFI, cut the fuel pump. It will require a Bosch type relay and a small switch. In fact, the small rocker type sold from Radio Shack. By turning off the fuel pump, no codes will be set if you crank it wihtout remembering to flip the switch back on.
the1998sr5
15
07-14-2020 08:35 PM
09-04-2015 09:27 AM
redneck17
07-17-2015 07:44 PM
Sandman
07-14-2015 12:36 PM
razorman8669
07-12-2015 12:13 PM
Quick Reply: Good spot to tap into efi for kill switch...
