Good compression AND blue exhaust smoke? - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 01-10-2011, 04:58 PM   #1
Yaddle's Avatar
Just a quick question. My 22RE reads 170 psi in a compression test, but I'm getting blue smoke out the exhaust when taking off after a long idle and on startup. Is it normal to see evidence of valve guide seal wear and good compression together?
I don't think anything is really wrong, I just thought these two things should never happen at the same time.
Yaddle is offline   Reply With Quote
Old 01-10-2011, 05:05 PM   #2
xxxtreme22r's Avatar
have you replaced/checked your pcv valve lately?
Add yes, valves can seal properly while the valve seals are worn since the valve seals do not affect the way a valve seats (thus good compression), unless the seals and guides are real bad in which the valve itself can "wiggle" a little causing them not to seat properly (thus bad compression)
But what you describe can be valve seals too so I can tell you have done your research.
xxxtreme22r is offline   Reply With Quote
Old 01-10-2011, 05:09 PM   #3
camo31_10.50's Avatar
Wouldn't a leak down test be better for determining the problem?
camo31_10.50 is offline   Reply With Quote
Old 01-10-2011, 05:26 PM   #4
not if the valves are seating properly. and with 170psi in the compression test, they definitely are.
Old 01-10-2011, 07:41 PM   #5
Yaddle's Avatar
Quote:
I've been meaning to check it. Now I've got a good excuse.
I see what you're saying. When the valves are closed, they would give good compression, assuming they seat well. But when they're open, oil and exhaust gas could escape past the guide seals.
Time to start reading up on the black art of doing a valve guide seal replacement without removing the head.
Old 01-10-2011, 08:25 PM   #6
94toyota's Avatar
Must be a 2 stroke
94toyota is offline   Reply With Quote
Old 01-10-2011, 08:44 PM   #7
sb5walker's Avatar
Usually, the symptoms you describe are caused by bad valve seals, yes. If you aren't already, try MaxLife 10W-40 - in a few weeks to a month you might see enough improvement to buy some time before you have to replace the seals.
sb5walker is offline   Reply With Quote
Old 01-10-2011, 08:54 PM   #8
Yaddle's Avatar
Quote:
Originally Posted by 94toyota View Post
Must be a 2 stroke
Well it has had an engine transplant...
Quote:
She's due for an oil change in 1 month, so I'll give that a try. I was also considering Engine Restorer as some others had had some luck with it. But I'm not sure dumping sludge in the engine to temporarily plug the leak is such a good idea. The amount of smoke is so minor right now that I'll probably just drive it until it becomes a lot more obvious.
Old 01-10-2011, 09:01 PM   #9
sb5walker's Avatar
My veezy was leaking a fair amount past the front and rear main seals, so last spring I gave the MaxLife a try and in 2-3 weeks I noticed the leaking almost completely stopped. I'm not sure how well it would work on valve seals, but it's definitely worth a try. Running the 10W-40 is good since heavier oil usually leaks less than lighter weight. In extreme situations, 20W-50 might be needed, but it's way too thick for winter.
Old 01-12-2011, 01:18 AM   #10
Yaddle's Avatar
Indeed it is. I'll give the MaxLife 10w-40 a try pretty soon since the window sticker says a change is due mid February. Amazon has it for $5.60 a quart (in the 12 pack) so I imagine I can find it somewhere for even less.
Old 01-22-2011, 12:05 AM   #11
Yaddle's Avatar
Walmart has MaxLife for $13.50 for 5 quarts so I'm going to go ahead and do the change. I'm also gonna put on a Purolator PureONE PL20195 following this thread:
http://www.yotatech.com/f116/will-lo.../#post51604096
Nevertheless I'm thinking I'm going to need at least a head job soon. A couple of days ago my yota didn't start up effortlessly like normal. No warning signs, just wouldn't kick over. I pumped the gas a couple of times and finally got it going. For the rest of the day, maybe 20 miles of driving, it was pumping blue smoke. I was sure either the head had blown or one of the valve guide seals had given up the ghost.
Since then I've driven 200 miles and the smoke hasn't returned. No coolant in the oil, no oil in the coolant. It's like it never happened. I'm glad her Wolverine healing factor kicked in and fixed the problem.
87 4Runner Rough Idle/Misfire issues Sleaker 86-95 Trucks & 4Runners 11 03-26-2016 05:12 AM
Its beginning to look a lot like a head gasket?! (overheating) the1998sr5 95.5-2004 Tacomas & 96-2002 4Runners 13 01-11-2016 10:55 PM
Another timing chain question thefishguy77 Newbie Tech Section 10 07-30-2015 11:59 AM
What exhaust pipe do I need? hexrain Prerunner & All 2WD Rigs 4 07-12-2015 02:13 PM
Questions about installing a new 3.0 Coreyr384 86-95 Trucks & 4Runners 2 07-10-2015 12:13 PM
Tags
blue, bluish, compression, e34, eng, exaust, exhaust, good, meaning, rebuilt, smoke, smoking, taking, times, wolverine
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
