going to be pulling and swapping motors 22re
Old 07-23-2011, 07:43 AM
rockinrebel's Avatar
Going to buy a long block 85-95 22re and swaping it with my 22re thats in my 88yota. When we replace it im going to have to swap some parts off the old motor and on to the new one. Will be replacing water pump, clutch, pressure plate, and fly wheel. Any suggestions on what i should replace as well when installing the new one to avoid mechanical or electrical problems?
Old 07-23-2011, 07:56 AM
Staff
Terrys87's Avatar
I didnt see you mention it, but would suggest oil pump and timing chain.
Old 07-23-2011, 08:07 AM
4x4climber's Avatar
New PCV valve OEM. new cap n rotor OEM. new ngk OEM plug wires. clean your oil pressure sensor. new oil pump aisin . new timing chain kit osk kit with steel backed guide.. New vacuum hoses and rubber nipple caps. Clean out your intake and throttle body completely. All this can be had (great quality oem stuff) at 22reperformance.com\
new air filter...
Old 07-23-2011, 10:11 AM
MrHunterman12's Avatar
I just did that and got my engine at http://www.chsmachine.com/ (7 year, 70,000 mile warranty). I got the hi-flow engine they offer (bigger cam, valves, etc MORE POWER lol).
I would recommend getting new bolts and nuts as when I was torquing mine down some of mine broke off right at the head (15lbs or less) and it was just a inconvenience. I also replaced the oil pressure sensor, water pump, oil pump, timing chain cover, fuel injectors, fuel filter, new belts, new pvc valve, new clutch kit. I also cleaned EVERYTHING (intake, engine compartment, parts, etc) and put some red paint on a lot of it cause it will match my ride
Have fun!
Old 07-24-2011, 02:03 AM
REALGRAVEROBBER's Avatar
I agree on the cylinder head bolts mentioned by the previous poster (NICE job by the way!).
A set of cyl head bolts was $17.
Old 07-24-2011, 04:41 AM
Badger62811's Avatar
Originally Posted by 4x4climber
... New vacuum hoses and rubber nipple caps...
He said nipple caps.... Tee hee... LOL...
I agree with all of the above. If you're already going to have the new engine sitting on a stand with easy access, replace as much as you can so you don't have to do it again at a more inconvenient time. I'd also go with all new hoses and replace anything else made of rubber.
Old 07-24-2011, 09:06 AM
hell yeah thanks guys, ill let ya know how it turns out. ill snap some pics too.
Old 07-24-2011, 09:43 AM
4x4climber's Avatar
DO NOT replace the timing cover unless there is a NEED for it. ALOT of these yotatech guys like wasting money doing that. Unless you have worn thru your timing cover there is usually absolutely no need to replace it. I too would go with a clutch. Get one from MarlinCrawler...
As for your injectors. NOT new . Just clean em or get em cleaned and rebuild em. anywhere from 20-80 bucks depending if you do em or send em off. They will be like 95% perfect when ya get done.
I just looked at my new nipple caps and they are crackd out...
bigjstang
08-25-2021 12:41 AM
MMA_Alex
25
04-18-2017 05:07 AM
coryc85
09-09-2015 06:24 AM
Jnkml
07-06-2015 01:20 PM
ptb12
07-05-2015 01:49 PM
Quick Reply: going to be pulling and swapping motors 22re
