GM Alt Bracket, the one wire hook up?
I know that I've seen them here before. I have searched for a while but can't seem to find one. Can someone please point me in the right direction. I need 2of them maybe 3.
sounds like the typical GM alt swap
seen it a lot on the 22r's, but I've never seen is on a 3.0
but most applications I've seen have been to replace or upgrade from the original alt, keeping the GM alt in the same location. hooking up a second alt to the system would more than likely require some fabbing of your own. why do you need a add a second alt?
I eneded up sourcing a 130amp direct replacement alt for my 22re
just remember to upgrade your wiring with a higher amp alt
It's a 22re and a 22r. I searched google, found nothing. I know I saw a bracket on here 6 months to a year ago. Should have got it then, but it was still a little while till I needed it.STUPID.
I bought one of these from Aaronn last year. :
https://www.yotatech.com/forums/f116...-mount-139333/
Still need to mount it but the quality is outstanding
Edit: Found his most recent thread on Pirate: http://www.pirate4x4.com/forum/showthread.php?t=830388
Only thing about a HO Toy alternator is the cost...the HO GM can be found in a ton of outputs, cheaper and more widely available...it's on my x-mas list
I'm interested in a second alt. or a bigger one, either way. Hadn't really looked into it just noticed the OPs post and thought I'd encourage response. I have 55W hellas on the truck right now and i'd like to add a set of Light Force 270s with 55W HID. I also plan to put in about 600W of sound system some day.
I've cooked a few alternators previously with said sound system alone. Yes its overkill, yes its un-neccessary but so are most extreme hobbies
montanatruck
02-26-2017 07:07 AM
whereAreMyPants
07-22-2015 03:32 AM
88yodabasket
07-13-2015 01:32 PM
