GForce Chips - Do they work?!?!
Old 01-06-2011, 03:46 PM
Blue 89 Runner's Avatar
What is the rated (crank) HP of an 89 22RE... 103 IIRC ? Also, IIRC, my 87 Turbo that I bought new way back then was like 135 ? That was a fun ride !!!!
Old 01-06-2011, 04:33 PM
MudHippy's Avatar
Originally Posted by VA07
So the percentage of drivetrain loss for a factory truck is 120/150=.86
1-0.86=0.14 or a 14% loss
Now taking their number of 140, this would equate to an at crank hp of 163 assuming the same 14% loss and ALL other conditions being exactly the same.
I agree that the cost for the product seems high for the gained HP. But assuming that a truck with 150hp will see the same 21hp loss as say a 1000hp truck with the same driveline is incorrect.
163 HP at the crank? That's still too low. Stock is 150, they claim +15-17, that should be 165-167 right? That's still 2-4 HP less than advertised then. So that don't quite work out right either.
Look, I'll go so far as to agree that there's another force to consider in determining drivetrain power losses. Where I remain highly skeptical is in regards to the actual significance of it. I mean what are we talking about numbers wise anyway? Or rather, just how much difference does that really make?
Let's try an experiment.
O.k. then, whe'll use the factory HP specs of 150 HP at the crank. And an actual dyno test measured 129 HP at the rear wheels. What's the real percentage difference there? Let's see 150 x 86% = 129. So exactly a 14% loss there, we know that much is true.
Alright so what's that work out to for a 1000 HP engine through the same drivetrain to the rear wheels? Let's see 1000 x 86% = 860. So all the sudden it takes 140 HP to turn the same drivetrain at 5000 rpm. Seriously? That's 119 HP more than the 150 HP engine. Hell, you've just lost a whole engine's worth of power right there!
There's no fricken way!
Let's try the opposite approach.
O.k. then, a 15 HP engine. Same drivetrain, same rpm. 15 x 86% = 12.9. So now it only takes 2.1 HP to turn the drivetrain at 5000 rpm. What? Are you kidding me? It's only 15 HP! It shouldn't even be able to turn the drivetrain at 5000 rpm.
Something just don't jive with the whole percentage loss scenario.
It's gotta be BS!
I'm jumping on the "there is no mathematical formula for determining crank vs. rear wheel HP" band wagon. This is suddenly no longer interesting. See ya!
Old 01-06-2011, 05:26 PM
VA07's Avatar
Cool! See ya later!
Old 01-06-2011, 05:51 PM
peow130's Avatar
Originally Posted by iamsuperbleeder
yup; pure junk, and anyone trying to convince you otherwise is full of it
the computer system in these trucks is so basic that there literally is no room for a computer programming upgrade without replacing the computer with new stand-alone systems
it would be like trying to supe up a calculator... why? there's really nothing that's so complicated that you have to improve upon it
Hey, what's wrong with suping up a calculator?
i put games on my TI-89.
Old 01-06-2011, 06:33 PM
  #25
X-AWDriver's Avatar
I don't see where magical HP comes from without introducing more fuel and air. I've been modding cars for almost 20 years and I've never seen a chip create HP on a naturally aspirated engine. Might as well slap a throttle body spacer on and a Tornado thingy in the intake.
Old 01-06-2011, 07:02 PM
  #26
xxxtreme22r's Avatar
BMW owners use with quite good results these: http://www.turnermotorsport.com/html...p?subcat_id=74
with 245,000 miles on mine, I am too scared to try one though.
These are also popular with the BMW crowd: http://www.dsylva-tech.ca/
ashersullivan88yota
01-18-2022 05:37 PM
sandyota
02-04-2021 11:16 AM
09-04-2015 09:27 AM
crashburnoveride
07-10-2015 06:39 AM
madxman21
07-09-2015 10:26 AM
Quick Reply: GForce Chips - Do they work?!?!
