getting moisture out of A/C
I have the grayish sludge from adding 134a to a system literally filled with water, like the evaporator was full of water. Can I just spray air into the low side and blow the sludge out the hi side. I know the proper way is to take it apart and blah blah blah.... but can it be done this way. Or is there another half ass way to do it.
I just wan't to experiment a little before taking it apart.
Getting moisture out of A/C
You need to take it apart, blow the crud out with compressed air followed by a good flushing with a cleaner intended for use in A/C systems.
If the evaporator has that much crud in it, the A/C system is probably ruined.
Why did the a/c have water in it?
Is this the same truck as this thread?
https://www.yotatech.com/forums/f116/everything-new-so-why-doesnt-my-c-work-114946/
and this thread?
https://www.yotatech.com/forums/f116/my-c-destined-not-work-116445/
and this thread?
https://www.yotatech.com/forums/f116/why-does-c-cycle-117551/
and this thread?
https://www.yotatech.com/forums/f116/one-12oz-134a-can-pressure-high-117614/
If so, it would be much easier for poeple to follow and provide help if you would stick with one thread.
and this thread?
and this thread?
and this thread?
bryan34w
12
09-30-2015 02:50 PM
