gears for 33 X 12.5s
Old 08-18-2007, 10:44 AM
playtoy871's Avatar
im thinking about adding a 4 inch lift to my 94 pickup and wanted some insight as to what gears i should put in if i run 33 X 12.50s. should i replace them at all? they are 4.10s now.
Old 08-18-2007, 10:46 AM
jfreisner's Avatar
4.88's for a manual
5.29's for an auto
Old 08-18-2007, 11:26 AM
playtoy871's Avatar
it's manual. same for the front end? how much will a set of 4.88s run me?
Old 08-18-2007, 11:29 AM
Jay351's Avatar
upwords of a grand for a shop to install them.
and yes you need the same gear ratio front and rear.
Old 08-18-2007, 11:36 AM
playtoy871's Avatar
how hard is it to do it yourself?
Old 08-18-2007, 11:38 AM
Jay351's Avatar
if you are not experianced with setting gears then I would not try it.
If you can, remove both 3rd's and send them out to get the gears changed then reinstall them.
that would save you some money.
Old 08-18-2007, 11:39 AM
playtoy871's Avatar
can i limp it around with the 4.10s for a while until i can spend the money on 4.88s?
Old 08-18-2007, 11:46 AM
Alex 400's Avatar
yeah but you will be working the clutch really hard and you will lose a ton of low end. gas milage will go down a ton probably and speedo will be off quite a bit too.
Old 08-18-2007, 12:07 PM
89-4Runner's Avatar
speedo will be off regardless of gearing...
Old 08-18-2007, 12:18 PM
racingcameron66's Avatar
i need to find out what gears are in my 98 taco.... any one have a clue????
Old 08-18-2007, 01:49 PM
Jay351's Avatar
Look for the axle code on your vin sticker on the inside of your drivers side door.
Old 08-18-2007, 04:17 PM
ovrrdrive's Avatar
When I changed my gears it put my speedometer back correct...
5.29's and 36" tires is almost exactly the same gearing as it was stock.
Old 08-18-2007, 10:14 PM
Bear80's Avatar
With a '94 don't assume you have 4.10 gears just yet. What is you're axle code? 4.88's are the way to go for 33s with a standard. If you have some local junk yards around see if you can find a Toyota set of 4.88 gears. '93-'95 3vze(V6) automatic trucks and 4runners came with 4.88 gears. I got a complete set for just $300.
Old 08-19-2007, 05:40 PM
tc
tc's Avatar
Originally Posted by jfreisner
4.88's for a manual
5.29's for an auto
x2, but I would consider 5.71's with the auto, as they are kinda undergeared from the factory
Old 08-19-2007, 06:44 PM
AuburnRunner's Avatar
yeah.. I'm going 5.71's w/ 33's. I just need to install a detroit before they go in... Anyone have any experience with this around Atlanta?
Old 08-19-2007, 07:09 PM
colsoncj's Avatar
4.88s and 33s brought me back to right on.
Old 08-19-2007, 07:17 PM
muddpigg's Avatar
www.gearinstall.com ZUK is well known and very knowledgible. I'll ask him to build my next 3rd.
Old 08-19-2007, 11:45 PM
Bear80's Avatar
Not with a '87 4runner. 60mph on your speedometer is actually 55-56mph, don't belive me pull out the GPS. Or you should check your speedometer gear or your guage cluster.
Old 08-20-2007, 03:22 AM
colsoncj's Avatar
For me, 60 miles per hour is actually 59.41 so not exactly 60, but close.
heres the math, simple ratio: 4.10/28 = x/33 solve for x.
4.10*33=28x (33" is new tire, 28" is stock tire)
135.3=28x
x=4.8321 (equivalent gear ratio)
now to determine how far off the speedo is.
4.8321/4.88=x (to get percentage)
x=.99019
60*x = ? or
60*0.99019 = 59.4116
Now if my truck came stock with 31s, 4.88s would make my 60mph on the speedo equal 53.66, but it came with 28"s stock. Everything would depend on what was the stock setup.
Old 08-20-2007, 06:00 AM
tc
tc's Avatar
Wow - a whole lot of calculations that are absolutely pointless because they assume the speedo is accurate from the factory - which in my experience, it's not.
If you REALLY want to know there are only two ways:
- time over distance with a stopwatch
- GPS (and even this may not be accurate enough)
We're really only talking about a few % here - you need a REALLY good measurement. Even police radar may be off by enough to not be used.
Quick Reply: gears for 33 X 12.5s
