Gear Shift Selector Light Bulbs In Instrument Cluster
I have a couple of bulbs burnt out on my 1991 Toyota Pickup with automatic transmission. Are these the type of bulbs readily available at my local auto parts store? Thanks
I am not sure which bulbs are for the automatic indicator lights, but I do know from replacing bulbs in various clusters that some seem to be easy to find in my area and some are not. I would just take the cluster out and remove the bulb to see what number it is. From there you can search your local parts stores online to see if they have it. If you have to order it online, you can just mount the cluster back in the truck so you can drive it while you wait for the parts. You do not need to put all the trim back on.
You can also try looking up a parts diagram at one of the online oem parts dealers. They might show the number of the bulb on the diagram, or you can search out the part number of the bulb to find it.
deerleasetruck
11-02-2015 03:13 PM
FS[WestCanada]: 1988 Sas'd toyota pickup
RoadRage
10-09-2015 07:43 PM
