Gear Question (multipule donor vehicles)
Old 07-14-2012, 05:18 PM
vanduzerwilliam's Avatar
I have a 89 pikcup sr5 4x4, I just went to a wreck yard, and they have 3 runners in there, and want to sell me the carrieres/gears (cheap!) They don't need them, or have a use for them. I pulled the numbers from the doors. If anyone could link the info so I can figure it out, or help me out id appreciate it. And I started to think if its a possiblity of one of the runners having a e locker I could use that and kill 2 birds with one stone. Instead of having to buy a elockers as well. And I could put a spool in the front and be set.
thanks in advance guys.
Red 4runner : production date 8/94
c/tr 3k3/jf11
A/tm g072
A340e
Green 4runner : production date 7/93
C/tr 6j7/gs11
A/tm g144
A340h
Black 4runner : production date 7/2000
C/tr 202/fa16
a/tm a03a
A03a
Old 07-14-2012, 05:19 PM
I want to figure out what gears are in which runner, and which one to get the parts from
Old 07-14-2012, 05:32 PM
bone collector's Avatar
http://www.brian894x4.com/Gearratiosanddiffs.html
all you need to know.
Old 07-14-2012, 06:00 PM
So the a03a off of the black runner is a open 4.10, I can't seem to figure out the others, im on my phone not on the computer, so I need to figure this out preety quick to find out if I want
to tell them to pull the carriers or not
Old 07-14-2012, 06:07 PM
toyota4x4907's Avatar
G072 is 3.90. Probably a 2wd, eh?
the G144 is 4.88
A03a is 4.10, but thats from a 3rd gen so it wouldnt fit in your truck anyways.
Old 07-14-2012, 06:17 PM
nothingbetter's Avatar
Slightly off topic...but you brought it up...DON'T SPOOL THE FRONT!!!!! Lunchbox or arb. Full locked in the front is a pain to turn, even on the trail. I can feel the driveline building pressure every time I forget to unlock my front.
Old 07-14-2012, 06:18 PM
So the g144 I could drop those and put those in my truck?
Old 07-14-2012, 06:20 PM
the g144 is a great choice. allows 33 or 35 in tires
Old 07-14-2012, 06:23 PM
NickMiller's Avatar
Yup! I don't think you should have any problems
I wish I could find a set for my 88... oh well
Old 07-14-2012, 07:00 PM
So the 4.88's are open, and id need to find e lockers or arb air lockers to lock both front and rear, as spool isn't a good idea
Old 07-14-2012, 08:55 PM
For the nood questions, but the carriers from the 93 will bolt up to mine? Or do I need to pull the gears from that to put into my carriers/housings.. never done gears before
Old 07-15-2012, 12:23 AM
NickMiller's Avatar
I haven't done gears before either, but if my research/memory serves me correctly, it should swap right in place... Get a second opinion before continuing though, because I'm not 100% sure... lol
Old 07-15-2012, 12:37 AM
All '79-'95 trucks and 4runners that use an 8" differential, either front or rear, will interchange and bolt up. No need to swap just the gears. The diff housing is the same (mostly) but will bolt up.
Old 07-15-2012, 11:50 AM
I found the aussie lunchbox lockers online with a 2 year warranty for around around 250-270 should I just put aussies in the front and back? Would that be a good reliable setup for mild/moderate wheeling and hold up to noob wheeling and as I get more experienced?
Old 07-15-2012, 11:53 AM
And I forgot to add, im probly going to pick up the 4.88's because im running 33x12.50 x16.50 right now. When these tires go. Im probly going to pick up new rims and run 33x10.50x15 not too fond of the 16.50's
Old 07-15-2012, 05:49 PM
rokblok's Avatar
Where in the world did you find 6lug 16.5 wheels? That's an oddity for sure. I just found a set of 4.88 factory doffs from a couple of different Runners in the local yards. The 3rds will all interchange. I already have a 4.10 V6 Runner complete axle under my '84, so the thirds will just be a bolt over swap. Luckily I will get to do front and rear with factory 4.88s. I hope they last.... I'm never one to have great luck with used parts. Lol
Old 07-15-2012, 08:13 PM
I was wondering where the flying hell the PO got 6 lug 16.50s from too.. and why??? Why not just put 15" rims... soo awkward.. but hey to each their own, maybe he had them laying around or something.
Old 07-15-2012, 08:45 PM
NickMiller's Avatar
It must be a pain to find tires for a 16.5 rim... I'd make the switch to 15's if I were you... lol
Old 12-02-2014, 03:04 PM
rustyota's Avatar
hi...you seem pretty knowledgeable....i have a japan made 94 4wd mini truck/hi/lux 22re auto w/ manual hubs....my bearings in the rear diff are wiped out and grinding 290k miles on it....question is will the rear from an 89 4runner ...3.0vze...non turbo..manual trans..manual hub vehicle work on mine w/o mods??? thank you in advance..john.
Old 12-02-2014, 03:06 PM
JasonYota's Avatar
Yes. Make sure they are the same ratios though.
oldirtydirt
02-23-2020 09:30 AM
mskalmus
05-28-2017 07:51 AM
rushw
07-18-2015 01:46 PM
Coreyr384
07-10-2015 11:13 AM
wilbertd
07-06-2015 07:39 AM
Quick Reply: Gear Question (multipule donor vehicles)
