gear problem?
Old 10-02-2012, 03:41 PM
Colbie's Avatar
gear problem?
whats up guys, i have a 1986 yota 4x4..4 wheel drive has always worked great....yesterday i tried to put it into 4 low, and when i let off the clutch you can hear gears grinding Either in the trans or t-case...It will work perfect in 4 hi, and 2wd..5 speed trans shifts out ok and doesnt gring at all..just 4 low, it's almost like the clutch isn't disengaging when i try to put it in 4 low.. any help is greatly appreciated..it does the same if locked in at the hubs or not locked in, it is a 4 cyl 22r. again thanks for any words or advice. i don't feel like it's anything major, when the truck was last parked 4 low was working ok. it sat a few months and now this problem shows up
Old 10-02-2012, 05:11 PM
youngtoyotatech's Avatar
Check fluid level for trans and t-case. Sure sounds like t-case issue. Trying to find details on hi-low shift.
Old 10-02-2012, 05:14 PM
Also slop in t-case shift linkage
Old 10-02-2012, 05:20 PM
rokblok's Avatar
Kinda sounds like its not fully engaging into 4lo. I would check shifter seat as well.
XtraCab
04-12-2020 05:25 AM
mskalmus
05-28-2017 07:51 AM
Seattle_Sign_Guy
07-12-2015 12:38 PM
Poncho0206
07-10-2015 06:21 PM
Jnkml
07-06-2015 01:20 PM
Quick Reply: gear problem?
