Gear oil all over the underside
I'm in the middle of a clutch replacement, and everything has what smells like gear oil all over it (smells of sulfur). It's on the top and bottom of the transfer case and transmission, and I just pulled the starter out and there's even traces inside the starter (not a lot, but noticeable.) There's also a bit on the bottom back of the engine block.
It's hard to believe anything is leaking, since I don't see it spraying or dripping and the transmission fluid and transfer case fluid are full. It seriously seems like someone just poured a bunch down the back of the engine and took off down the interstate.
What could be causing this? I have a new transmission input seal and a rear main seal, but where else could it be leaking?
But I'm still looking for other sources. This is ridiculous. I don't want to replace the clutch with a new (and expensive) heavy duty clutch and have this foul up because of oil contamination.
Not that I can see.
It's literally all over the transmission and transfer case. Top, bottom, sides, everywhere. I'd get a picture, but I blasted most of it off with the pressure wash a few weeks ago in preparation for this. At the time, I didn't realize it was this bad.
i believe there is actually a breather...i remember reading that somewhere.
could be input seal, or output seal, or both.
could be leaking out the top of the tranny or t-case..where the shifters are.
mine was doing that because the bolts had worked themselves loose...and then the gasket was ripped..lol
The last time mine was off I used ultra grey and it hasnt leaked yet. been 15000 miles.
Ultra gray is what I have on hand, and so far that's working good for the subaru's leaky oil plate, so I guess ultra gray it is. I won't go with a dealer gasket for this because 1) RTV does good enough, and 2) money is tight and I just paid $60 for the input seal and the rear main seal from the dealer.
I'm not looking forward to cleaning the transmission, as I would like to take it outside and blast it off. Sadly, it won't leave the garage until it's attached to the truck again.
Here's a picture of the topside of the transmission. These are where the shift levers go:
Imagine that layer all over the entire transmission and transfer case. Yes. EVERYWHERE. For some reason, it's not on the body, drive shaft, propeller shaft, or anywhere around them, so it doesn't appear to be whipped around the transmission bay.
to bring this back to life, I am also having a leak. did you find out what it is? I just did a rear main seal and the valve cover because I thought that was what was leaking, but its still leaking. Now to think of it, I did take the shifters out to pull the trans and the gasket did not go back on correctly. I never thought that it could leak from the top of the shifter, but I will check now.
On mine, there was an ok-sized leak on the input shaft seal, and it was all over the back of the engine and on the bottom of the bellhousing. If it smells like gear oil and it's coming from that joint, it's likely to be either that or (at the guys above said) from the top of the shifter.
yeah, I had a leak just like that on the bottom of the engine right where theres the plate between the engine and bell housing. It was my rear main seal, I went in there and fixed it. it is still leaking from the same spot though(and my rear main was leaking, maybe why I couldnt tell if it was engine oil or gear oil)
https://www.yotatech.com/forums/f116...g-pics-231579/
now if its my trans input seal, I dont have to worry about it getting on my clutch right? its just gunna leak down the bell housing and out? I really dont want to pull my trans again.
XtraCab
04-12-2020 05:25 AM
mengquis
07-13-2015 10:39 AM
Jnkml
07-06-2015 01:20 PM
