gear help
Old 08-27-2007, 02:16 PM
Toy-SkiTzo's Avatar
gear help
i broke a spider gear in my rear diff (dont know how but i did) i swaped it out with some new ones and now im getting a defferent pattern the pattern was perfect before but now its like this
and suggestions
to me it looks like i need to adjust the pinion depth but i dont see why all i changed was the spiders
thanks for the help
steve
Old 08-27-2007, 02:42 PM
tc
tc's Avatar
I'm certainly no gear expert, but the first thing that comes to mind is new crush sleeve or solid pinion spacer?
Hopefully, Zuk will chime in soon with the real answer.
This post certainly supports my theory that gears have to be re-set-up (at least checked by someone who knows what they're looking at) after installing a full carrier locker...
Old 08-27-2007, 02:44 PM
Toy-SkiTzo's Avatar
it was rebuilt about a month ago with a solid spacer
Old 08-27-2007, 07:07 PM
GSGALLANT's Avatar
What's your backlash set at?
Old 08-27-2007, 07:29 PM
Toy-SkiTzo's Avatar
.007 thou
Old 08-27-2007, 07:47 PM
ZUK
ZUK's Avatar
Is that a Richmond gear?
Old 08-28-2007, 09:26 AM
Toy-SkiTzo's Avatar
no i bought it at PORC ill and dont quite remember their brand
Old 08-28-2007, 09:28 AM
Toy-SkiTzo's Avatar
also i checked the pinion preload last night and its really low (1-2in LBs) is that normal for a brokin in diff? i know a freshly set up diff should be 10-12
Old 08-28-2007, 10:29 AM
tc
tc's Avatar
I thought a new one was 10-12 and a used one was 8-10. Regardless, 1-2 is WAY too low.
I come back to the solid spacer/pinion shim setup.
Old 08-28-2007, 02:37 PM
ZUK
ZUK's Avatar
Loosing the pre-load like that is normal. If the bearings are cryo treated the pre-load will last 2 to 4 times longer.
Your coast pattern looks off....too close to the heel. But with used gears that have worn in one exact spot, finding that spot again can be tricky. try INCREASING the BL a little....that will pull the coast to the toe end.
mskalmus
05-28-2017 07:51 AM
norcal98
08-10-2015 06:20 AM
wolfpackfan33
08-02-2015 03:36 PM
Shaun Crystal Gomban
07-30-2015 10:13 PM
justdifferentials
Just Differentials
07-22-2015 08:26 PM
Quick Reply: gear help
