Gauges are in....check.
Old 04-01-2009, 05:31 AM
Lotus1's Avatar
Well finally got my pod gauges in and I love them. I find that I stare at them all the time now.
I bought the pod from Jeff Mosk here…
http://www.truckpillars.com/
I initially bought a 2 pod pillar but then decided to go with a 3 pod pillar because I wanted to add a trans temp gauge to it. So I have Autometer Phantom gauges in an Oil pressure, Water temp and a Trans temp.
I initially had the red light on them. The red was really cool but in the end I decided to go with the green lights to match the dash better.
I commissioned a mechanic friend of mine to do the install. Let me tell you that was the best decision I made. I could’ve done the install myself but I just didn’t have the time to do it. It literally took him 3 days, on and off, to do the install. He did an incredibly professional install on it.
All the wires were soldered. All the connections were wrapped in heat sink. Wrapped in wire covers. Ziptied. No tape or twisty wire connectors were ever used. For the trans sensor he tapped into the trans pan drain hole. What’s cool about it is that if I want to drain the fluid I just need to unscrew
the wire off of the sensor and unscrew the center part and it drains perfectly.
Old 04-01-2009, 05:36 AM
toyminator2000's Avatar
The gauges look good but I think its a dumb place to put the trans temp gauge. Looks like he used the drain plug hole.
Old 04-01-2009, 07:30 AM
894x4pickup's Avatar
x2 that looks like it be the first thing to rip off on a trail.
Old 04-01-2009, 08:01 AM
Lotus1's Avatar
My friend owns a machine shop and I talked to him yesterday about making a protective plate for it. lol
Old 04-01-2009, 08:40 AM
Dan.3's Avatar
Originally Posted by Lotus1
Old 04-01-2009, 10:44 AM
874runnersr5's Avatar
looks like that thing could get hung up on something. glad someone else realized to
Old 04-01-2009, 11:31 AM
space-junk's Avatar
wow... nice lookin set of gauges there...
ive been wanting to get an a-pillar pod too because the stock gauge cluster is a little lackluster...
Old 04-01-2009, 01:21 PM
iamsuperbleeder's Avatar
...No tape or twisty wire connectors were ever used...
I see tape...
but still a pretty clean install; you should see the wiring to mine, lmao
X's 3 on that trans-temp probe though!
other than that little quirk, they look good!
Old 04-01-2009, 01:55 PM
Lotus1's Avatar
I see tape...
LOL. Dammit, I forgot about that tape.
Yeah, like I said in my post above I'm gonna try and get a protective gaurd for it somehow. If I can't I'll consider drilling into the side of the pan and welding the sensor in like I've seen done before. thanks
Old 04-01-2009, 02:09 PM
stagger_lee's Avatar
I think they look sweet! I'm jealous.
Old 04-01-2009, 03:22 PM
Jay351's Avatar
Sweet! I got the same pod, looks fantastic. I just need gauges..
Old 04-01-2009, 05:27 PM
stepside trd's Avatar
Why not just drill the side of the pan and then tap the hole to accept the same threads as the plug?? Just my 2 cents....
ashamsuddin
17
01-13-2023 03:17 AM
kawazx636
10-06-2021 03:03 PM
zanzabar0
10-11-2015 02:56 AM
Jdgarrison
10-01-2015 05:22 PM
dbollier123
09-29-2015 05:23 PM
Quick Reply: Gauges are in....check.
