gauge installation - wire color question
Old 03-17-2011, 04:38 PM
SDHNTR's Avatar
I am going to install an aftermarket temp gauge in my 88 with 22re. What color is the hot wire for the ignition switch? I need that to power the gauge. Then what color is the wire for the lights? I need to know which ones to tap into. Thanks.
Old 03-18-2011, 05:28 PM
gamudslinger88's Avatar
I am also wondering this for my 91. I installed an aftermarket tack and had to wire the light to keyed 12 volts. I am not sure about your 88 but the book says white wire with black stripe is the lights. I tried this and couldnt get it to work so I dont know what the deal is.
Old 03-18-2011, 06:26 PM
weaselman's Avatar
if you look at the wires behind the stereo, the red is switched 12v, yellow is constant 12volts. and orange is illumination 12volts.
bigjstang
08-25-2021 12:41 AM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
coryc85
09-09-2015 06:24 AM
toyota32
07-06-2015 05:42 PM
Quick Reply: gauge installation - wire color question
