gas tank repair? - YotaTech Forums
Go Back   >
gas tank repair?
LinkBack Thread Tools Search this Thread
Old 09-04-2007, 11:44 AM   #1
mojo4x420's Avatar
gas tank repair?
Posting for a buddy. He has a 91 pickup. He replaced his gas pump on the weekend and when he went to open the drain plug on his gas tank, it was fubard. From his description the plug turns, but the threads are ed. He wasn't able to remove the plug or retighten and it it's leaking some gas.
So I was thinking about just trying to weld the plug shut w/ my 220v stick welder.
Anyone have any idea ho I would go about this w/out blowing myself up?
Maybe not worth it. Anyone know if another gas tank would fit in from something other then a 3rd gen pickup?
cheers, rob.
mojo4x420 is offline   Reply With Quote
Old 09-04-2007, 11:49 AM   #2
cheers, rob.
I can get tanks around here for $100 (used) for almost any vehicle. It is not worth blowing yourself up!
CT
CanadianToy is offline   Reply With Quote
Old 09-04-2007, 12:00 PM   #3
eric-the-red's Avatar
Let me know which part of Vancouver you're in, so I can watch for the explosion
eric-the-red is offline   Reply With Quote
Old 09-04-2007, 12:01 PM   #4
tc
tc's Avatar
The epoxy tank repair stuff works pretty well.
tc is offline   Reply With Quote
Old 09-07-2007, 08:13 PM   #5
Be sure to top the tank off before you weld it. Bigger explosion that way.
toby's toy is offline   Reply With Quote
Old 09-07-2007, 08:19 PM   #6
linuxrunner's Avatar
When I was in africa I saw a guy welding a hole in a desel tanker truck, just welding right on the side of the tank and it was one of those huge tankers that delivers gas to gas stations.... it was crazy!!
linuxrunner is offline   Reply With Quote
Old 09-07-2007, 08:20 PM   #7
MMA_Alex's Avatar
DO NOT WELD A GAS TANK UNLESS ITS BEEN GAS FREED, and certified gas freed.
best bet would be some of that epoxy liner for the tank.
oh, and diesel is different, although i still wouldn't weld a diesel tank there are a number of stories about lit cigarettes being put out in diesel tanks.
MMA_Alex is offline   Reply With Quote
Old 09-07-2007, 08:21 PM   #8
CJM
CJM's Avatar
Or you could try and remove it and retap that bolt with a larger one and use a gasket around it.
CJM is offline   Reply With Quote
Old 09-07-2007, 09:17 PM   #9
tc
tc's Avatar
Quote:
That will happen with gas too - the liquid isn't flammable, only the vapor. As such, the recommendation to fill the tank above actually DOES increase the safety because it displaces the vapor with liquid.
Old 09-08-2007, 07:29 AM   #10
scrid's Avatar
gas tank repair
I usually remove them, drain, and take them the car wash and blast them out good after removing the sender/fuel pump assembly. Then sit them out in the sun for a few hours until thay dry up before welding.
In a pinch I would recommend that Magnum gas tank repair putty, I have used it before and it works great,...until it could be properly repaired that is
scrid is offline   Reply With Quote
Old 09-08-2007, 03:35 PM   #11
MMA_Alex's Avatar
Quote:
you're welcome to try it, and put a video on youtube.
Question, '78 20r, starts up but dies unless I continually pump gas pedal DiZ86 Pre 84 Trucks 12 12-27-2015 10:33 PM
Has anyone seen what happens to sugar if it makes it to a gas tank? skoti89 General Vehicle Related Topics (Non Year Related) 4 09-11-2015 08:46 AM
22r Smog troubles accuracy 86-95 Trucks & 4Runners 6 08-04-2015 09:05 PM
1991 Pickup - 3VZE fuel line / filter stripped out. How to replace? pyramid 86-95 Trucks & 4Runners 10 07-30-2015 11:05 AM
Cross Country Trip: Cali > Florida in a 91 4x4 3VZE: Should I be worried? pyramid General Vehicle Related Topics (Non Year Related) 6 07-29-2015 07:53 AM
Tags
fuel, gas, information, instant, itw, magnum, nak, omaha, plastic, repair, resistance, steel, tank, tanks, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
