gas leak front of frame??
Old 08-02-2008, 02:00 PM
bigt's Avatar
help me find a gas leak!!!
its coming passenger tire side of the frame
cant see any leaks!!
fix a portion of lines with rubber hose and they work fine... tried looking while truck was running and couldnt find it either
heres a pic
please help me!!
im about 1200 dollar in parts in my ifs trail rig and just want to have some fun!!
Old 08-02-2008, 02:09 PM
Five1Nine8Eight's Avatar
Fuel filter maybe?
Old 08-02-2008, 02:11 PM
bigt's Avatar
i tried feeling it and couldnt feel anything.. right now i think its draining somewhere into the frame!!
Old 08-02-2008, 05:58 PM
Matt16's Avatar
Trace the lines. The filter is on the block on the passengers side if it is a 22re.
Old 08-02-2008, 06:10 PM
bigt's Avatar
now i went for a drive and i cant see a leak anymore ???
wow this is weird
Old 08-02-2008, 08:35 PM
ozziesironmanoffroad's Avatar
put a fuel pressure gauge in, it should show if you have a leak. basically, if you have a leak, it will read low fuel pressure. or if they have the florescent dye they use for leaks available for gas, use that.
Old 08-03-2008, 07:38 AM
bigt's Avatar
yes its back today.. just a small drip from the first 3 holes int he frame and no gas leaking anywhere eles.. it drives fine like its getting enough gas....ive been looking for it for an hour
im giving up and going to look at my new green project pickup!!
Old 08-03-2008, 07:45 AM
Yoda's Avatar
The vent tube for the vapor caninster goes into the frame there. Canister may be leaking.
Old 08-03-2008, 01:27 PM
bigt's Avatar
THANKS YODA!!! YOU ARE MY MASTER
lol
if not im just gonna replace back to front with rubber wince its a offroad only vehicle!!!
gotta get this truck finished cause i got a new one comming shortly!
Old 08-03-2008, 01:53 PM
4Crawler's Avatar
Follow the rubber hose off the bottom of the charcoal canister, it runs down and gets stuffed inside the frame rail. Normally only a vent hose to let in fresh air to replace gas fumes in the cannister as the engine sucks them in. However, if the cannister gets clogged or something else goes wrong (see FSM for troubleshooting steps) gas can leak out that hose off the bottom of the cannister. Cannister should have two lines on top, Purge line to the throttle body, the tank line goes to the tank and the 3rd hose off the bottom is the vent:
Old 08-03-2008, 01:54 PM
bigt's Avatar
it could have got clogged when i almost hydro locked in a mud bog!
Old 08-03-2008, 02:34 PM
bigt's Avatar
ok it seems your right its coming from cannister..the fsm says to blow it out...
ill give it a try!
Old 08-03-2008, 05:51 PM
PCE91V64x4's Avatar
Can you hook up the lines and just delete the canister?
Old 08-03-2008, 08:18 PM
4Crawler's Avatar
The cannister is part of the emissions control, so legally no, can't do that. Plus it is a reasonably "good thing" to have, the cannister sucks up gas vapors from the tank as it heats up during the day. Then when the engine is running, those fumes get sucked back into the engine to burn. Without the cannister, those fumes just go up into the air and with the price of gas these days, that may be a costly proposition.
Charecter1
11-06-2023 10:08 AM
lledwod
08-30-2016 01:03 PM
Yota.Jay
07-23-2015 08:08 PM
Avenged
07-09-2015 07:55 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: gas leak front of frame??
