Gas gauge not working
Old 07-10-2015, 05:53 PM
Tyler Cunningham's Avatar
Have recently did a holley 500 carb swap on my 87 toyota p/u 22r during the swap i switched over to a electric fuelpump (one that goes outside of the tank) a few months later the pump burnt out so i switched back to the factory mechanical fuel pump and since then my fuel gauge will not do anything i know that i have at least 1/4 tank of gas i have pulled the sending unit and tryed lifting the arm manually and still nothing i have even put a new one in it and still will not read. The gauge worked perfectlly with the electric one and worked before i switched fuel pumps and i am completly stumped any advice would help a bunch
Old 07-10-2015, 10:20 PM
Turd Furgeson's Avatar
When you are manually lifting the arm is the key on,and are you grounding it to a good ground?
Old 07-11-2015, 05:55 AM
Yota.Jay's Avatar
Whats been previously stated and to add it maybe the sending unit. In my 87 toyota...the gauge acts funny...i put 1/4 tanks it reads full or sometimes nothing. I haven't played with it. I just keep a gas can in the back of the bed and watch my mileage
Old 07-11-2015, 10:18 AM
Yes the key is on ive eve tested it with the truck running and all of the factory wiring is still being used for it i have not spliced or cut into any of it
bigjstang
08-25-2021 12:41 AM
Cplmike
07-08-2015 08:47 PM
Jnkml
07-06-2015 01:20 PM
Steezy96yota
07-06-2015 10:00 AM
karbin
07-05-2015 11:37 PM
Quick Reply: Gas gauge not working
