| New! Use your Facebook to securely log into this site, click logo to login |
| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
G52 to W56
__________________
1987 4WD Pickup|Xtra-Cab|Rebuilt 22r|G52|Redline MT-90|289,xxx miles|LCE carb adapter|Edelbrock stainless air cleaner assembly|K&N 15" air filter|Sunpro 88mm supertach II|SR5 Bucket Seats|MC shifter seats & socket|Stull Grill|LCE Street Header|Magnaflow Cat|2.25" Exhaust|235/70R15 Goodyear Wranglers|15x8 Eagles Build Up |
#2 (permalink) | |
Super Moderator-Sponsoring Member
Staff
Quote:
__________________
WabFab Off-Road, LLC MySpace 7th Annual South East 4Runner Jamboree, 2010 Jeeps are cute. Ken drives one. This extra space provided to you at Tofer's request and now for rent to the highest bidder. |
#3 (permalink) |
FWIW-- my shifter hits my t-case when going in reverse sometimes on my w56
#4 (permalink) |
Me too. Maybe the t-case shifter can be rotated in its base somehow?
__________________
Rust-Free '88 Runner. Stay-at-home truck. |
#5 (permalink) | |
Quote:
As for the tcase this is the matching one. W56 top Shift. Or you think I should find a forward shift w56?(89-95)
__________________
1987 4WD Pickup|Xtra-Cab|Rebuilt 22r|G52|Redline MT-90|289,xxx miles|LCE carb adapter|Edelbrock stainless air cleaner assembly|K&N 15" air filter|Sunpro 88mm supertach II|SR5 Bucket Seats|MC shifter seats & socket|Stull Grill|LCE Street Header|Magnaflow Cat|2.25" Exhaust|235/70R15 Goodyear Wranglers|15x8 Eagles Build Up Last edited by streetlancer; 01-05-2010 at 04:15 PM. |
#6 (permalink) |
Ok, here are some pics. If you see anything wrong speak up.
__________________
#7 (permalink) |
Here are some more. This is what i meant seems to be be missing half of the bottom but at the same time it looks factory because of clean cut. Is this right?
__________________
#8 (permalink) |
anyone? Im trying to get this running again.
__________________
#9 (permalink) |
The hole in the bottom of the shifter looks just like mine did when I did the same swap. the shifter on the tcase looks like it might be mounted backwards? Mine looked the same though and I ended up bending the shifter tower a little so it would shift nice.
To modify the floor I cut the tunnel section of the floor out of the donor 4runner from around the shifter hole and planned to used it like a sheet metal skin over the floor pan of my truck. I ended up only using the very tip of the tunnel to cover the opening where it stuck out from under the front of the shifter. I herculined the crap out of it to cover up the patch job, but the cab was an automatic to begin with so the floor already had some 'issues'. |
#10 (permalink) |
Well thanks for the response, maybe now i can get started on the swap. It just seemed strange to be missing half of the bottom. I was afraid it might have fallen in and on first start grind up all the gears. The one in the g52 is a full circle.
__________________
1987 4WD Pickup|Xtra-Cab|Rebuilt 22r|G52|Redline MT-90|289,xxx miles|LCE carb adapter|Edelbrock stainless air cleaner assembly|K&N 15" air filter|Sunpro 88mm supertach II|SR5 Bucket Seats|MC shifter seats & socket|Stull Grill|LCE Street Header|Magnaflow Cat|2.25" Exhaust|235/70R15 Goodyear Wranglers|15x8 Eagles Build Up Last edited by streetlancer; 01-06-2010 at 06:29 PM. |
| Tags |
| 4runner, cut, g52, gear, grinding, line, mt90, pictures, red, reverse, swap, tcase, toyota, tranny, transmission, w56 |
