Fusible Link Wire
Fusible Link Wire
Is the wire that goes from the positive battery terminal to the 80 AMP fuse in the box "fusible link" wire or ordinary wire?
I had to cut mine years ago to replace the terminal. I crimped a new end on, but it's annoyingly short. I'd like to replace the wire, but I'm not sure what to use.
It's a 1986 22R. The wire is long enough (barely now) to reach from the box to a post on top of the battery terminal.
If Toyota hadn't confused matters by calling the fuse a fusible link, this would be a lot easier to figure out.
kirkrunner
07-27-2015 07:59 PM
