Fuses melting?
Fuses melting?
Anyone having any problems with their fuse melting thats goes to the taillights and dash lights?....ya well mine is shorted somewhere and melting fuses, any suggestions?
87 4runner 22re
87 4runner 22re
Melting? Wow, sounds like a hard short. Take a look at your wiring and see if any of it is bubbled or discolored more than the surrounding wiring. If it's pulling that much amperage and heat to melt a fuse, it should be making itself known the the wiring as well. If you can, also check continuity.
Not really. Just need to see where it's shorting at and rewire past that. So follow the crispy wire and see where its doing it. To do a good job, a simple soldering iron and new same gauge wiring and electrical tape can do the job.
the ole boy is right..lol..my Amp fuse by the battery would blow..so in order for it to work on cruise night..i put in a 5amp bigger fuse..problem solved..lmao..although it melted it after a while..but nothing was harmed as far as i know..
it could just be a loose connection somewhere..so check all of your connections bud!
RyanJ989
11
04-07-2021 09:41 AM
bryan34w
12
09-30-2015 02:50 PM
Scotttekoch
09-28-2015 10:30 PM
